Results 1 to 4 of 4
    Veteran Member Three Rings Unispeed's Avatar
    Feb 22 2007
    Earth
    What should my O2 sensor voltages be at IDLE? Want 14.7AFR.
    The title says it all...
    2015 Audi A4 2.0TFSI (GEN 3 engine) with DL501 transmission (GEN 2 tran.)
    (B9 A4 engine mated to an S4 transmission in a B8.5 chassis. )
    2000 S4 6spd stg 2+ (gone but not forgotten)
    Oct 22 2008
    United States - DE
    Re: What should my O2 sensor voltages be at IDLE? Want 14.7AFR.
    Your voltage from your O2 sensors should normally rise and fall somewhere between 0-1v when your car is warmed up. Why would you want to tune for stoich at idle? I would worry about your AFRs under WOT, not idle.
    Feb 22 2007
    Earth
    at WOT its perfect... thank for the info
    Aug 06 2008
    Canadia
    .9V is what it should read at idle, generally at WOT a cars o2 sensors go into open loop and the injectors go to maximum duty.
