Results 1 to 8 of 8
    Established Member Two Rings Avantugofast's Avatar
    Jun 13 2007
    car won't start details inside
    I drove around yesterday morning just fine, stopped for lunch, came back out and nothing. Push started it and got it home, drove fine. I bypassed the clutch postition switch and still will not start. No codes either.
    Could it be the ignition or the starter? Why no codes?
    Thanks for any input!
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: car won't start details inside
    Quote Originally Posted by Avantugofast View Post
    What happens when you turn the key? Crank? Click? Could be a dead or dying starter if you can push start it but the engine doesn't turn with the key.
    08 S4- Stock SOLD
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    check the engien ground near the starter..and all the connections going to the starter.. clean them and try again.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Jun 13 2007
    Quote Originally Posted by JDM EJ1 95 View Post
    is the starter easy to access from underneath?
    Thanks
    Jun 13 2007
    Quote Originally Posted by mholme View Post
    Nothing, i don't hear anythin from the engine or under the car, the dash lights come on like usual.
    Feb 28 2007
    chicagoland
    Thanks
    not EASY but its attainable.
    Nogaro 01 s4
    620whp 93octane
    Jul 20 2004
    sounds like my issue - im replacing my starter
    Jun 13 2007
    Quote Originally Posted by tdimpreza View Post
    Yeah im getting ready to check mine. Maybe the "tap" fix will work
    So do you have to remove the front lock carrier/bumper to replace the starter?
