Thread: Boost Help
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Boost Help
    So i recently got my boost gauge installed with the help of some people and on the T fitting tubing on one of my hoses ripped. So i cut some of the excess tubing from the awe boost gauge that they awe supplied me with and zip tied that back on, everything seems to be in working order, im just a little confused as to how much boost, stock is running?
    I have a tip and when i floor the car the boost gauge stays around 10, and then when it shifts drops to about 6-8 and then goes back up around 10 again. Is that normal?
    Also when i get into the higher rpm's the boost level drops to about 6-8 and when the car shifts it does that also. Is that normal?
    Mar 11 2007
    1990 R32 GT-R
    Somewhere in CT
    Re: Boost Help
    Stock boost is around 8-9 PSI at WOT.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Boost Help
    so is my boost normal?? also when it gets into high rpms and when the car shifts is it supposed to drop to 6-8 and then go back up to 10?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: Boost Help
    Sounds fairly normal, but I've never driven a stock S4
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Registered Member Two Rings
    May 07 2008
    98' Jetta GLX, 68' Coronet
    Dalton Oh,
    Re: Boost Help
    when the car shifts your boost will drop since it is determined by how much exhaust is coming out of the car. when you shift the rpms drop causing the boost to drop. when you go at higher rpm though you should be at a higher boost so if it goes lower at higher rpm that doesn't seem right to me. Thats just my basic knowledge of turbos though.
