Results 1 to 17 of 17
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Boost Gauge Help!!!
    So i recently got my boost gauge installed with the help of some people and on the T fitting tubing on one of my hoses ripped. So i cut some of the excess tubing from the awe boost gauge that they awe supplied me with and zip tied that back on, everything seems to be in working order, im just a little confused as to how much boost, stock is running?
    I have a tip and when i floor the car the boost gauge stays around 10, and then when it shifts drops to about 6-8 and then goes back up around 10 again. Is that normal?
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Re: Boost Gauge Help!!!
    giac should be around 15ish psi if im not mistaken . My GIAC X-XR runs my k04's at 18-20 psi
    --Black 2001.5 -S4- 10secS4 Tuned
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    sounds right, stock is around 10 psi.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    i understand that but like when i get into the higher rpm's the boost level drops to about 6-8 and when the car shifts it does that also. Is that normal?
    Registered Member Two Rings s2000_s4_525's Avatar
    Apr 25 2007
    B5 S4 stage 3+++/ Turbo s2000
    Canada, British Columbia
    giac 15-17 depending on situations. With my experience at least.
    Stage 3 s4 Wicked Motorsports... / S2000 turbo/ Soon to expand....
    Veteran Member Four Rings JackalS4's Avatar
    Mar 01 2008
    Toronto, ON, Canada
    Mine is manual but it holds 8-9 PSI perfectly steady to redline (stock).
    Not sure if the tapering near redline is normal on Tips or not though...possibly programmed that way? Not sure..
    As for the tapering during shifts, i'd guess that should be normal as you might lose a bit of boost during the shift.
    Brilliant Black 2001 S4 - 6MT <3
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    yeah thats my questions because i was thinking maybe i have a boost leak??
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    any suggestions or maybe this is normal?
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    are you stock or chipped?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Jun 15 2007
    stock 7-10
    giac 16-20
    Driver Supply
    Current
    '18 Audi TTRS
    Sold
    '13 black Audi S7
    '03 Porsche 911T
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    yea man, if ur sig is correct, GIAC should be hitting anywhere from 16-20 psi depending on ur GIAC file and if u have an MBC in parallel w/ it. My MBC is set to spike around 19 psi, sometimes I see 20, occassiionally i'll see 18 psi
    Do you have stock DV's?? check em. Is ur car a 2000?? Check the f-hose. Other hoses aren't as common as these to so you then will have to pressure test if both your DV's and f-hose are okay
    hope this helps
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    thanks for the info, and i do have stock dv's and they seem to be working. Also what is the F-hose, and i do have the giac x chip but its on the stock setting.
    My question is though is when i floor the car, when it gets to higher rpm's the boost drops like around the redline and when it shifts it also drops to about 6-8psi. i also have a tip not manual. Is this normal?
    Jan 29 2007
    08 S4 00 S4
    MD
    Quote Originally Posted by 00s4slvr View Post
    Don't worry about an f-hose, you've got a tip that doesn't have one.
    08 S4- Stock SOLD
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    boost tapers in higher rpms. i wish it held 17-20 all the way through the power band...its normal for it to SLOWLY drop.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    so i did some more runs today and actually my boost looks like its at 9-10 and then around the redline before it shifts drops a little maybe to about 7-8 and then when it shifts it drops to about 6-8 and then shoots back up to around 9-10.
    For stock setting does this sound normal?
    Jun 14 2007
    2000 S4
    Connecticut
    yes sir... the reason your boost drops slightly (tapers off) in the higher RPMs is because the higher in the RPM range you are you are demanding more fuel and to maintain a safe A/F ratio the car has to taper some boost off so that it doesn't lean the car out up top... On stock it may not be a big deal but say if you were in chipped mode and spiked 18 and held that, as the injector duty cycle raises with the RPMs you would be dangerously close to maxing out the injectors and leaning your motor. so yes, unless you have a MBC in standalone (you'll still bleed boost but not as much) it is 100% normal. my stage 3 software is programmed to spike to 24, taper to 22.
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    thanks for all the info.
