Results 1 to 21 of 21
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Need to know a few things
    1st Is the Altenator from a 2000 s4 going to work in a 2001.5 s4 motor?
    I dont know what Altenator(bosch or valeo) the motor had since there is nothing there.
    2nd The shifter box from a 2000 s4 would it be compatible with a 2001.5 s4 tranny?
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Need to know a few things
    the plug and pulley styles are different on the bosch/vaelo i beleive. so id assume youd have to match it up to the plug on the harness.
    i couldnt tell you about the years though.. im not sure on that one
    the shifters should be the same
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    Nov 14 2006
    Land of the Eagles
    isn't the rev,erse position different on the those models iirc the reverse on 01 is push down,left side and forward(close to 1st gear) and the 00 is push down right side and back (close to 6th gear)?
    Feb 28 2007
    chicagoland
    Quote Originally Posted by GiacGRs4 View Post
    hmm i didnt think it was that way? i could be wrong though lol
    Nogaro 01 s4
    620whp 93octane
    Nov 14 2006
    Land of the Eagles
    bump
    Feb 28 2007
    chicagoland
    bump
    lol this forum doesnt move that fast tehe..
    Nogaro 01 s4
    620whp 93octane
    Nov 14 2006
    Land of the Eagles
    i am used to the a4 forums with in 10 sec you are down on the 7th page :)
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    Mines a 00 and it's press down and up to the left kind of where 1st is.
    Feb 28 2007
    chicagoland
    Quote Originally Posted by Rapter View Post
    yea ive always known vw/audi to do it this way..
    Nogaro 01 s4
    620whp 93octane
    Nov 14 2006
    Land of the Eagles
    hey where in Clifton are you?? i live there also do i know u ?
    so the shifter boxes should be the same?
    May 01 2004
    2009 honda CRV
    Jersey
    Sorry man I don't live in clifton I live close to hackensack which isn't too far away. I'm not sure who you are, but I think I have an idea who you are and seen you at Kenny's a few times.
    Nov 14 2006
    Land of the Eagles
    hahahah yeah i go there, have we meet? what color is ur s4?
    Nov 14 2006
    Land of the Eagles
    Quote Originally Posted by JDM EJ1 95 View Post
    well the 97 a4 that i HAD, had a push down then right back close to 4th.
    Nov 14 2006
    Land of the Eagles
    bump still need to know about the altenator
    Oct 31 2007
    F21-e85 S4 MKIV BPM R(T)32
    Grand Rapids, MI
    I don't think the shifter boxes are the same, as all the aftermarket SS are made in 2 versions, the "old style" shifter for 00 and "new style" for later 01 and 02
    MKIV BPM R32 (DD)
    2000 B5 S4 3L GT2860 build in progress...if only I could get my parts quick enough
    Jan 29 2007
    08 S4 00 S4
    MD
    The pulley is different from bosch to valeo. If you're putting on a used one, just compare it to the old one and swap if need be(you'll probably need impact air to get it off). Remans sometimes come with a new pulley, sometimes don't.
    08 S4- Stock SOLD
    Established Member Two Rings S obsessed's Avatar
    Sep 27 2007
    North Dakota
    Either alternator will work as long as they have there own pulley. The pulleys are not interchangable. In my experience most parts places get the bosch(just make sure it comes complete with pulley). I am running a bosch on my car that originally had a valeo.
    2001 s4 6sp stage 3
    Nov 14 2006
    Land of the Eagles
    ^^^thanx man, any ideas on the shifter box?
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Box will be fine. All B5 S4s in the states have push down towards 1st. Only the 5 speed pre facelift b5s had it next to 4th.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Nov 14 2006
    Land of the Eagles
    great, really appreciated your response also
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    no my 00 6speed Reverse is left of 1st like every other s4 ive seen
    '00 Nogaro Blue S4
