Originally Posted by
JDM EJ1 95
yes it wears FASTER than the rest.. but all in all the actual tire material isnt wearing prematurely.
if you had 0 camber youd still have to replace your tires at about the same interval as if you had -2deg
provided toe is dialed in
like i said its a huge common misconception by tons of people.. when lowering a vehicle that the camber induces faster tire wear.. which in actuality it doesnt.
when you lower a car.. toe is pulled in as well. this is what causes premature wear.. if you get the toe fixed.. then you are back to normal tread wear.. besides the fact that its unevenly distributed...
but like i said you wont be replacing tires noticeably faster or more frequently if your toe is dialed in.
Ok. Let me make this clear......
A tire's contact patch is made to handle the entire load of the vehicle. It even carries a rating which is a numericle value: 92, 93, 94 etc...
When the camber is excessively negative, the full load is now focused into a much smaller area. While the tire can handle this, it creates extra friction on this area because the weight is not distributed evenly across the tire. Added friction creates added heat. Added heat causes this section to wear faster than the rest of the tire. This is why the inner edges become bald. While the outter edges are not wearing, this inner edge wear will occur QUICKLY.
I can tell you firsthand that the inner edges will show obvious signs of treadwear in 5,000 miles from the original date of installation of new tires.
Now you rotate the front tires to the rear of the car. The rear tires now take this abuse for 5,000 miles and the wear is identical to the ones that were moved to the back.
This is the best way to handle the situation because you can get 15-20,000 miles out of a set of tires.
If you forget to rotate them at 5,000, you can expect the tires to be down to smooth tread by 10,000. The last set of tires I replaced on my B5 A4 had 13,000 on them and they were just starting to show the metal belts at the inner edges. Meanwhile, the middle to outter tread sections still had roughly 4-5mm of tread depth remaining.
This was not a toe issue. This was not a control arm issue. I replaced the control arms 3 times on that B5 and checked my alignment at every set of new tires. The problem was that my front camber was always around -1.4 degrees. My rears were around -1.24 and didn't wear nearly as quick as the fronts.
On a non-lowered car, you can go 10,000 miles between rotations and still get even tire wear. For example, on my A6, I have 20,000 miles on a set of tires that I installed in April and they still have 5mm of tread depth remaining. Original tread depth was 10/32" or 8.5mm.
***The bottom line here is that running excessive negative camber will wear out the inner edges much faster than it would take to wear the whole tire's surface if the weight was spread evenly.***
BTW, here's an writeup I did on aligning the B5's suspension:
Click.
The max recommended camber for the front axle is -1.08 <> -0.24 degrees. Lowered cars easily exceed -1.08 degrees.
