Hi,
I have a B6 Avant - but a friend bought a 99 A4 from his brother... I pulled these codes from his car. It is getting about 17mpg on the last tank. I am thinking the MAF could be causing some of this, but the first code is a little hard to find info on. I cleared everything, and will check with him on monday and do another scan.
6 Faults Found:
17913 - Throttle Idle Switch (F60): Does not Close or Open Circuit
P1505 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-00 - -
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 35-00 - -
17604 - Oxygen (Lambda) Sensor Heater Circuit: B1 S1: Electrical Malfunction
P1196 - 35-00 - -
17746 - Camshaft Position Sensor (G40) Open or Short to Plus
P1338 - 35-10 - - - Intermittent
Can anyone shed some light?
thanks in advance
