Results 1 to 6 of 6
    Oct 24 2008
    Atlanta
    Question about painting my calipers
    hey of you guys wanna give me any opinion on what's the best way to get this done? Would you prefer hand paint or spray paint? what kinda paint do I need to buy and where? and what kinda brush do I need to use? Do i need to put clear coat after? All suggestions are appreciated.
    Veteran Member Four Rings Sal_B7's Avatar
    Dec 11 2007
    2005 A4 2.0T Quattro 6Spd
    San Diego, CA
    Re: Question about painting my calipers
    Duplicolor has this paint specifically for brake calipers. It comes in a spray and then they have this kit that comes with spray and a thing for doing it with brush. The brush i think will work better but the spray does a good job as well. You might want to get a steel brush and clean off any break dust or anything that might be caked on to them. I painted mine black and they came out pretty good! You can find the paint at kragen or autozone. Good luck!!
    '05 A4 2.0T Quattro MT APR Stage 3
    2008 APR Holiday Giveaway Winner!! Thanks APR!!
    FRRG Southern Ring
    Xbox Live ID: Sqzn2zz
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    Quote Originally Posted by Sal_B7 View Post
    yup autozone has them, i used the spray one and it works fine i washed them first and then the sprayed them+ i gave it a coat of clearcoat. shinyyy
    GIAC-X, STASIS TS,VAST,034 MS
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    I would hand paint if leaving on the car like i did, or if you are taking them off the car you might as well spray paint them. It will be easier for you. They have a whole kit that comes with cleaner and paint for you. It is a pretty simple job. just make sure you tape everything off very well!
    The usual things!!
    Resistor Install
    Active Member Two Rings mataylor1's Avatar
    Aug 21 2008
    2008 A4 SE 2.0T Quattro
    Falls Church, VA
    i used to paint calipers at a detail shop i worked at, we used to simply tape off the rotor, cleqan them extremely well, with a degreaser preferably, then spray a coat of primer, then hit it up witha few coats of paint to ensure complete coverage, then hit it with some clear. i would recommend the duplicolor one, but we used to use krylon before duplicolor was avaiable, it worked fine, never hqad any problems with chipping or anything, good luck and hope this helped.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    G2 caliper paint from tirerack is the way to go. For about 35 bucks you get a whole kit that has the caliper cleaner, paint, and brush. I did it that way and didn't have to tape off anything give yourself some time though because you can't drive the car for 24 hours and it takes a few hours to put a couple coats on. You can search my name and caliper paint to see pics. I can't copy and paste right now cuz I'm on my phone...
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
