Results 1 to 14 of 14
    Senior Member Two Rings ScaryGary's Avatar
    Nov 29 2007
    Silver 04 Audi A4 1.8T 6-Speed
    Sacramento
    Question what's this "wideband" jargan?
    I see it referenced in more in-depth tuning threads and there is really no explanation I can find.
    Specifically, someone was trying to adjust A/F via lemmiwinks, and another poster strongly recommended he use a "wideband" for measuring or tuning or something of that sort.
    I'd appreciate an explanation!
    thanks
    calm the fuck down. it's all relative.
    Dec 06 2007
    Re: what's this "wideband" jargan?
    custom program that monitors everything about the car and allows everything to be adjusted it has a piece that attaches to ur exhaust and monitors exhaust flow and what not.
    -Kirk
    BetaAlphaTau Member #58
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Not flow, but the amount of oxygen in the exh. To much and the motor is running lean, too little and the eng. is running rich. Optimum for our cars is about 12.5:1 @ WOT.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings maxspeed's Avatar
    Dec 14 2005
    Shakedown street, NY
    its an auxiliary oxygen sensor that gives extremely accurate air fuel ratios instead of lambda or "narrow band" values
    2000 Audi A4 1.8TQM - RIP
    1999 Subaru Outback
    When your spirit is floating down that tunnel, towards the light, You know what's behind the light?
    It's not God, it's me. And I'm gonna kick your poncey soul All the way back down the tunnel 'till you choke on your own fucked up ribs! Now, Wake the fuck up!
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Mar 21 2006
    Lakeland, FL.
    WOW 19.0:1
    "This option is especially important in new fuel control concepts such as lean-burn engines, where the engine’s fuel control changes at cruising speeds from 14.7:1 to a much leaner 19.0:1 or even higher."
    I'm back bitches!
    Jul 30 2008
    2003 A4 1.8TQM5
    PA
    I think some Civics used to have that lean burn thing, like a 1994. Read that it is a popular car among hypermilers or whatever they are called.
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Your car has a wide band sensor.
    May 21 2007
    Florida
    not to thread jack, but how much do out o2 sensors cost? got a CEL for them the other day.
    2018 Navarro Blue Q5
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by maxspeed View Post
    no "narrow band" here.
    this is B6 country. all widebands
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Jul 07 2004
    socal
    Quote Originally Posted by doublezero30 View Post
    Anywhere between $65-$80 for the VW 5 wire wide band 02 sensor. The ones from the dealer might be slightly longer then the ones that are sold buy aftermarket companies.
    Buncha motorcycles
    Memphis, TN
    try $200 from audi.. i would love to know a VW part number that would work instead for my front and rear o2s
    APR Stage 2/AWE Intake
    Jul 07 2004
    socal
    Quote Originally Posted by Papachristou View Post
    Well the one from the dealer has a longer cable. Nearly all of the aftermarket wide band units use a Bosch wide band 02 sensor which sells for $79.
    VW AG
    021906262
    0258007 057/058
    bosch 02 sensor
    Sep 17 2006
    SLC, UT
    being on the forums long enough, you should know to NEVER go to the dealer
    Current:
    Previous:
