Results 1 to 13 of 13
    Veteran Member Four Rings chrissurfr's Avatar
    Apr 26 2005
    Houston
    Extended warranty and mods......
    I'm about to turn the dreaded 50k on my car and am debating getting an extended warranty. I have a CVT with a chip and just don't trust the thing. If I get the warranty and get a bigger turbo etc and the tranny craps out on me....will I be covered? How does this usually work?
    2017 Cement Grey TRD Pro 4runner
    2014 Suzuka Grey RS5 >:)
    • AWE Track Exhaust with center muffler straight piped
    • H&R Street Coilovers
    • BBS CH R - Gold with red caps
    • eCode headlights
    • Eventuri intake
    • JHM Stage 2 ECU/TCU
    • other things I forgot about
    Dec 31 2006
    boston, ma
    Re: Extended warranty and mods......
    Quote Originally Posted by chrissurfr View Post
    which warranty...aftermarket or audi?
    Apr 26 2005
    Houston
    Undecided....which ever is best???
    • eCode headlights
    • Eventuri intake
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    umm i dont think the warranty will cover BT, so just save urself the money you'd be spending on the warranty and upgrade your tranny
    21' Audi RS6 | E30 M3 | 996 Turbo | Corrado SLC | IG: @stevedavid993
    Apr 26 2005
    Houston
    it's cvt kinda hard to do. What about injectors and an intercooler only?
    • eCode headlights
    • Eventuri intake
    Dec 31 2006
    boston, ma
    well any aftermarket warranty will use any excuse not to cover something...even so much as using a different size tire will void the entire warranty...the audi warranty will have to prove that whatever you changed as far as performance caused the failure of a part
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    I have had such bad luck w/ aftermarket extended warranty companies...
    If you do get one, just go w/ one approved by Audi. If you mod, IMHO, choose easily reversible ones as warranty companies do everything in their power to deny claims.
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Oct 06 2008
    2003 Audi A4 Quattro 5-speed
    Felton, DE
    I had the Audi CPO. After putting on a Carbonia CAI, my MAF went bad. CPO would not cover because of the aftermarket part. $485.00 later, I had a brand new MAF!!
    Dec 31 2006
    boston, ma
    Quote Originally Posted by RobC1979 View Post
    because the mod you did directly connects to the maf, they do not have to cover it, on the other hand, if something else like an o2 sensor went bad...they could not deny you..
    Senior Member Three Rings drevil2k2's Avatar
    Aug 29 2007
    GTA
    It's a tricky thing with the extended warranty and mods. When I purchased the Audi CPO extended warranty, they had to do an inspection of the car. Luckily, it was before all the mods and the dealership serviced the car up until that point.
    I usually try to revert to stock if possible before heading to a mod friendly dealership to get repairs done. My personal experience, I had 3 coolant leaks and one vacuum hose leak, all covered under warranty. The fuel pump went 4 weeks before the recall, but it was covered anyways. For me, since the car was leased, the extended warranty was a no brainer.
    However, if you plan to extensively mod the car and engine, then as others suggested, take that money and put it into your car.
    May 29 2008
    i'm thinking about the same thing.
    i'm looking at the audi extended and for my car it's 2 year, 24000mi for $2100 or 3 year 36000 mi for $2600.
    i'll probably get a new car within the 2 years so that's the one i'm looking at.
    they said pretty much everything is covered except normal wear items. i asked about timing belt. belts are not covered, but they said it would if it goes out before the usual time.
    i really think i'm gonna do it.
    i guess what i'm asking is. i have no mods so is this a no brainer that i get this warranty?
    i have to decide by tomorrow.
    Veteran Member Four Rings yung turbo's Avatar
    Feb 19 2008
    2005 A4 1.8TQtip-2011 A4 2.0tQAuto
    NYC/DE
    im in the same position. i have until march 9 or 50k and im debating on the 100k ext warranty.
    TuRboK1ng
    You Are All Witnesses
    And The Yankees WIIIIIIIIIIIIIIIIIIIIIIIIIIN
    The Yankeeeeeeeeeeeees WIIIIIN!!!!!!!!
    Veteran Member Four Rings Turbo1A4's Avatar
    Aug 04 2008
    2002 s4 nogaro
    Jax
    i just got an aftermarket warrenty that covers engine, tranny, quattro system, turbo, ect and i told them that i was upgrading everything they said ok cool....no problem so i got my warrenty
