Results 1 to 2 of 2
    StaSIS Engineering and Vivid Racing team up for Audizine! Proven power for your Audi!
    If you're familiar with STaSIS Engineering, then you're well aware of the quality, engineering and proven power gains they've produced with their products. Their high end products offer OEM efficiency and driveability.
    -The Facts-
    STaSIS Engineering’s new Power Kit is designed uniquely for your 2.0TFSI A3. Produced in conjunction with Mahle Powertrain, this turbo upgrade is engineered to achieve maximum performance while sustaining OE reliability. Performance with peace of mind; the STaSIS Power Kit comes complete with a 1-year/15,000mile warranty.
    -The Power
    Stock 2.0T A3 STaSIS Kit A3
    Horsepower 200 300
    Torque 207 290
    STaSIS’ Power Kit delivers more power throughout the rev range. While other kits peak and surge, the Power Kit delivers seamless power at all speeds. Increased power across a dynamic range of engine speeds gives the Power Kit factory quality drivability. With the STaSIS turbo upgrade your A3 will become a high-performance daily driver.
    -The Warranty-
    The STaSIS Power Kit will give you the performance you desire and peace of mind you can live with. The kit comes complete with a 1-year/15,000 mile parts and labor warranty when installed and serviced by a STaSIS certified installation center. The attention to OE component limitations built into this kit by STaSIS and our Mahle partners allows us to extend our warranty beyond the STaSIS components to cover the complete power plant from intake to flywheel. The warranty is limited to non-competition use and does not extend to all driveline and wear items. For specific warranty details please review the ‘STaSIS 2.0 Power Kit Warranty’.
    -The Tech Specs-
    STaSIS’ Power Kit minimizes turbo lag by replacing the OEM turbocharger with a larger, more efficient assembly. Use of pulse matching technology, like that found in twin scroll designed turbochargers, allows higher air flow rates at lower engine speeds. High flow fuel injectors allow sustained wide open throttle use and a redesigned diverter valve provides long life under high temperature conditions.
    Tired of searching for all the components necessary in a turbo upgrade? We’ve eliminated the hassle by including all the components necessary for increased performance and OE reliability.
    Included in the kit:
    · State-of-the-Art turbine design
    · High-flow Fuel Injectors
    · Redesigned diverter valve
    · ECU Upgrade
    · STaSIS Silicone Hoses
    · All gaskets & hardware included
    As one of the 14 authorized StaSIS Engineering authorized installer, Vivid Racing can also perform this installation if you are local. PM me for install rates for Audizine members. Also check out our combo featuring the StaSIS turbo kit and the forge front mount intercooler kit, seen HERE
    PM for Audizine pricing!
    Re: StaSIS Engineering and Vivid Racing team up for Audizine! Proven power for your A
    It's boosting time! Friday bump!
