Results 1 to 13 of 13
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    need quick answer to impossible question
    how much oil does a 2000 2.8 v6 have?
    How many quarts do i need to buy?
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    Re: need quick answer to impossible question
    doesn't it say in the manual?
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    if it did i wouldnt be asking lol
    Veteran Member Four Rings Great White's Avatar
    Oct 07 2008
    Pinarello Prince w/Record 10sp
    Raleigh, NC
    Quote Originally Posted by le91688 View Post
    ROFL
    Did you google it?
    Oct 30 2006
    B8 A4 Avant 6spd
    Wild Guess 6-7 Quarts?
    2.7 takes 7, but that has turbos to fill.
    -18 718 GTS
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    i found this
    which says 5.3 U.S. quarts (5 liter)
    So i got 6 bottles of Castrol Synthetic 5w40, so just keep a little?
    Dec 04 2007
    New York, NY
    I always buy 6 quarts and usually end up with 1 -- 1 1/2 left over.
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    mine took all 6 to get to a good level.
    __________________
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    My 98.5 takes 6.5 quarts
    Veteran Member Three Rings generik777's Avatar
    May 12 2007
    1998.5 A4 2.8 Quattro Tip
    MN
    Quote Originally Posted by TverRus69 View Post
    My 98.5 takes 6.5 quarts as well. The book does say by the way but it doesn't give the correct amount. I always buy about 8 quarts at a time use the 6.5 and then keep the remaining 1.5 quarts in the trunk just in case. Now give me a prize for doing the impossible.
    Senior Member Two Rings gsverz's Avatar
    Oct 05 2007
    North Jersey
    <IMG SRC ="http://i7.photobucket.com/albums/y293/FastA4Turbo/audi/FluidCapacityChart.gif">
    Oct 05 2007
    North Jersey
    Aug 17 2008
    Also, look closer because it is in your owners manual.
