Page 1 of 4 123 ... LastLast
Results 1 to 40 of 132
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    The count down begins...........
    Until 1/4 mile time
    But the car is trying to do me dirty but I will conquer in the end!
    The tube coming off the turbo manifold down to the wastegate had a bolt fall out causing an exhaust leak. I put in a new bolt but guess the gasket got messed up from the leak and is now snapped in half. I am trying to take the other half of the gasket out but cant get the other allen headed bolt out. I am gonna try to get under the car with my Snap On impact and get it out with that because i put everything I had on it with my ratchet and it didnt budge. Then when messing with that I noticed my coolant sensor was tilted to the side in the coolant flange on the back of the head. Well that baby was getting ready to let go. Half of the plastic clip was broke that holds it in and the o ring looked terrible too.
    Going to lunch in a few with a friends gf and she is gonna bring me to the Audi dealer across the street from where we are eating so I can get a new o ring and plastic clip (thank god I live here in Jacksonville now where there are actually places to go to get parts and not have to order them). That will fix that problem then I will be back to dealing with the exhaust leak on the manifold (gotta get that damn bolt out) without taking the manifold off I hope.
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Oct 29 2005
    10speed
    San Francisco, CA
    Re: The count down begins...........
    good luck man its always something
    - Clint
    Jan 25 2006
    A4 2.0T
    MD
    44MM FTW....
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    That external wastegate on the ATP manifold used to fuck with me on a regular basis...
    Probably the most embarrassing part is when Paul Lambert of STaSIS jumped into my car to bed in the brakes, he went out onto the track at Infineon Raceway and did a lap or two...when he brought the car back, the wastegate adapter piece had broken and the car was on zero boost and a fat ass exhaust leak.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Was it one of the allen bolts for the WG to manifold? If so, when you install the new one take a center punch and stake the edge of the WG so the bolt can't back out.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Apr 24 2005
    E55 AMG, CTS-V
    yes an allen bolt but it is one that threads in to the manifold to hold the 90 degree rotation piece that has like a 3" long pipe coming off it that the wastegate then bolts to the end of. Not one of the 2 bolts that hold the wastegate.
    Just put in the new o ring and clip, now it is time to tackle the bolt some more, and I have a lock washer to put on with the new bolt now.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    Is it the plate from 034?
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    No it is an ATP item. It has the 38mm wastegate flange on each end with like 3" of pipe between them and then it had the flanged welded 90 degrees from each other so it spins the wastegate facing backward from facing to the passenger side. It is the bolts that go through the top flange of that piece in to the manifold.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    Ok, I know what part you're talking about.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    Got the bolt out! The impact and 4 extension did it Now I just need to find a gasket locally. The first place didnt have one, hope the next one does or I am gonna have to hope it seals good without one.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    If you can't get a gasket, take a file to both flanges until they're smooth and use some high temp silicone. That'll seal it.
    I'm back bitches!
    Jan 25 2006
    A4 2.0T
    MD
    Mar 21 2006
    Lakeland, FL.
    Those are nice, but sometimes the ring will allow the flanges to bend if the temps get to high for to long, at least it did on my 034 rotation flange.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    Well nobody has one in town so I put it back together without a gasket. I felt around it for a few seconds and think it wasnt leaking but im not to sure, it got to hot fast so I had to move my hand. I dont hear any leak though so that should be good enough for tomorrow atleast.
    ~David~
    CTS-V 9.6@148
    Veteran Member Four Rings Audi Skate Snow's Avatar
    Mar 31 2004
    C300 Sport and tools
    CA
    David its always something. pay someone to do it next time ;)
    BetaAlphaTau member #1.5
    R.I.P B6 A4!!!!!! 12/03/2005 12.63@108... stock 1.8 motor W/ GTRS.
    B6 A4 Avant, 2.0 Liter, 3071, Maestro
    Apr 24 2005
    E55 AMG, CTS-V
    Pay someone to do what? I would never pay someone when I can do it myself and save a boat load of money. And a friend ended up having a gasket so I will take it back apart and put the new gasket in tomorrow morning.
    ~David~
    CTS-V 9.6@148
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Gaskets FTL.
    Mar 21 2006
    Lakeland, FL.
    The Final Countdown, di da di do, di da di da do. Anyone?
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    so close I can taste it
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    So open for a gay joke...refraining...refraining.
    I'm back bitches!
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    Quote Originally Posted by dirtybrd View Post
    http://www.heavy.com/video/59751
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Gaskets FTL.
    serisouly!
    just make sure the flange for the wg tube is completely flat and bolt it to the mani.
    gaskets used to blow out of mine all the time.
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by nihil View Post
    Wow.
    I'm back bitches!
    Apr 24 2005
    E55 AMG, CTS-V
    What the......... I can't believe I watched the whole thing to haha
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by sean1.8t View Post
    serisouly!
    If you want a 100% pure seal it takes a bit of work. Have you ever used a honing stone for knives? First you spray a little WD40 on the flange and stone, next rub the stone on the flange. Right off the bat you'll feel the stone dragging on the flange, these are high spots. You want to rub the stone on the flange until the dragging subsides and the flange is even in color. Next you take some Prussian Blue made by Permatex and apply a thin even coat to one of the flanges. Assemble the 2 parts and torque. Disassemble the parts and read the flanges. Want you want is the blue to transfer from one flange to the other completely even. That will give you a total seal. It's how we seal the fittings on the steam turbines at my job.
    I'm back bitches!
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Hope all your probelms work themselves out. My car's down now as well, and I'm hoping to get it back on the road by mid-next week.
    Some fast things and some slow things
    ~Josh~
    Veteran Member Four Rings golgo13's Avatar
    Apr 29 2007
    Tampa Bay
    GL
    SweetnLou!
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by mtbrider View Post
    what happened josh?
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    May 24 2007
    Southern California
    haha. realllyyy!!??!! i think its funnier that you know that video exists and remembered it because of the title. lol.
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings A4 Moda's Avatar
    Jun 11 2005
    2003 Audi A4 1.8TFSM
    SoCAL- City of Industry
    oH my....
    It's always something man.
    Sorry to hear about that.
    Keep up the good work.
    Stay positive.
    Eurocode TINY Turbo GT71R Eliminator:: REVO Tuning::
    2003 1.8T
    Eliminator||Carbonio V2||ATP EXhaust Manifold ||Neuspeed TIP (Eurocode)||JOE P MBC @ 22PSI B9- Timing 5||Custom 3" Exhaust||Mangaflow Mufflers|| Revo||Reiger||Boser hood||S4 Bixenon Ecodes||LED Tails||Eibach Coilovers||
    Oct 31 2005
    Virginia
    Quote Originally Posted by B6Lovin View Post
    what happened josh?
    I had a charge issue and I blew my headgasket. Both problems have been taken care of its just now getting everything back together
    ~Josh~
    Jan 25 2006
    A4 2.0T
    MD
    Charge issue?
    Mar 21 2006
    Lakeland, FL.
    Charging issue.
    I'm back bitches!
    Feb 17 2005
    Sarasota, FL
    Beautiful day out, awaiting times!
    Apr 24 2005
    E55 AMG, CTS-V
    Track opens at 4:30, we will see what happens.
    ~David~
    CTS-V 9.6@148
    Mar 21 2006
    Lakeland, FL.
    I was gonna go the Bradanton last night, it had cleared up a bit so I checked their website, but they were having Outlaw Shootouts this weekend and Nostalgia next weekend. So it'll be at least 3 weeks before I can go again. I guess I could ge to Tampa or Orlando
    I'm back bitches!
    Veteran Member Four Rings bwoy1981's Avatar
    Oct 28 2006
    2005 Porsche 911 997 Manual, 2022 Hyundai Tuscon
    Orlando, Florida USA
    ^^ Hey Chris if you come to Orlando, the best days are Wed's and Fri's. Let me know if u do..
    Current: 2022 E-Tron Sportback Premium Plus, Siam Beige, S-Line, Black Optic Package, 22x10.5 Vossen HF'5's, 285/35/22 Continental DWS 06 PLUS
    TOY: 2005 Porsche 911 997 Carrara White / Black Interior 6 Speed manual, Aero Kit,
    BC Racing Coilovers, FABSpeed Exhaust, Headers & Intake, 991 GT3RS Reps "GOLD"
    Mar 21 2006
    Lakeland, FL.
    I'd have to be a Friday, what time do they open? I work over there now and get off at 6. Just checked, they don't have Street Drags that I could do until the 7th. But it is only about 10 miles from my work. I work out at OUC, building the new power plant.
    I'm back bitches!
    Jul 07 2004
    socal
    Quote Originally Posted by A4 TSCHUSS View Post
    Lucky, must be nice to race at night.
    Jan 25 2006
    A4 2.0T
    MD
    4:30! blah
