Results 1 to 4 of 4
    Veteran Member Three Rings A4p's Avatar
    Mar 06 2006
    Audi 1.8TQM6 S-line USP 2004
    Sweden
    service maintaince
    Hey guys i was wondering what are the most importing things to look after. the winter has come and i have only changed the oil.
    USP CLUB MEMBER 861
    Rev0 stage I file - 300+ bosch injector - OFE SS - APR Snub mount - Nitrogen - RS4 Swaybar - K&N air filter - **-
    Veteran Member Four Rings Arclight's Avatar
    Dec 20 2006
    8VS3
    Re: service maintaince
    The current mileage on your car would be helpful for routine maintenance issues... i.e., @ 75K the H20 pump and timing belt need to be changed...
    At a minimum, I check the coolant and tire pressure (colder temps = lower tire pressure) as the winter months approach. I also switch out to my super-sexy winter tire setup (steelies) at the first hint of snow...
    For Sale: HRE 501s, 19 X 8.5 and 19 X 9.5
    Mar 06 2006
    Sweden
    yeah i have nitro on my tires :). my car has 80xxx right now. so saying timing belt and wich coolant do you talk about??
    Timing belt
    coolant wich coolant??
    K&n Air filter. have ordered
    Oil filter have orderd mann filter
    what else??
    USP CLUB MEMBER 861
    Dec 20 2006
    8VS3
    Use G12 radiator coolant from the Audi/VW dealer.
    Also, your spark plugs should be changed every 35K. If you have noticed a drop in gas mileage, fresh plugs will help that situation. You may also want to change out your fuel filter if it's never been done before...
