Results 1 to 6 of 6
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    ProDiag on Palm, Vag-com Q's
    I have ProDiag on my Palm, I can scan for check-engine light, and clear it, but rather than that, I don't know what I can do...
    I've played with it a little last night, I could check systems, and I know I can monitor the engine, but how do you change stuff with it?
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Feb 17 2004
    Sterling, VA
    Re: ProDiag on Palm, Vag-com Q's
    If my memory is correct, you could do basic functions on Pro-diag but, you were not able to recode modules with it.
    Pro-diag is meant to be a portable code scanner and measuring block reader.
    If you want to recode any of the control modules or do real logging, you need VAG-COM.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Apr 01 2008
    Massachusetts
    but there are options for coding and logging in and stuff...when I click it, I have no idea what to do next...have to put in some values, but no idea what to do and what can be done...
    Apr 01 2008
    Massachusetts
    then how do you recode with Vag-com?
    where could I find instructions?
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    search is your friend for that man. Ross tech has DIY, every forum has them too. I think the B6 A4 forum has a write up on using the ebay cable that is pretty hard to mess up.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Veteran Member Four Rings Gigi's Avatar
    Jan 23 2006
    2004 Audi A6 2.7T, 1999 Jeep W
    Charlotte, NC
    you can record with it like tip recode, auto door lock, window up/down by remote ....
    Just find the righT code or # add ons on the Internet and plug them in the right module. In each module, once you are in there is a code section/ box, click on that and change code
    I have on and it works
    Have a great day, Brice
    99 Jeep TJ, 4" lift, Mikey Thompson rims & tires
    http://i157.photobucket.com/albums/t...i/photo-22.jpg
    http://i157.photobucket.com/albums/t...20TJ/Jeep2.jpg
    SOLD: 04 Blue [B]A6 2.7TStage 2 +: Many mods
