Results 1 to 3 of 3
    Veteran Member Three Rings mike's machine's Avatar
    Apr 01 2008
    Ducati M750 900SS Honda CBR600rr Ruckus
    Massachusetts
    Driver side window motor...
    My driver side window motor went bad, so I bought an used on eBay, which is supposed to be from pass-rear.
    I thought they were the same, it fits, bolts right in, but now it works BACKward...
    In order to open the window, I have to pull up the kob, in order to bring it back up, I have to press the switch...
    Is this something you can change some how???
    With Vag-com??? or any other way???
    Please HELP!!!
    C5, Giac, 2Bennet , UUC, snub, 034, piggies, RS6 SE catback, rear S4 BBK, RNS-E, JHM, darintakes, K&N, forge, samco, rs6 reps, OZ Ultraleggera, phat box, 4.2 blades, clear corners, LED tails, tinted - SOLD
    Rolling on AR 402, H-sports, Milltek Turboback, O.CT tune, LWFW w/RS4, Stoptech ST-40 332mm fitted in stock 17", hyperboost BPV, Quad-xenon
    Established Member Two Rings 2000 A6 2.7t 6m's Avatar
    Jul 27 2007
    PA
    Re: Driver side window motor...
    Being from the opposite side of the car, it should work in reverse... idk about vag, but switching the wires should work?
    Click for Photo Album
    Upgrades:
    APR 93 ECU -=- H&R Coilovers -=- H-Sport Swaybars -=- VMR B7 RS4 Reps in Onyx Black -=- Upgraded Sound System
    Apr 01 2008
    Massachusetts
    how do you switch wires? there are like 8 wires plugs into the motor...
    and automatic up and down does not work either...
