Ziza A3 LED License Plate Bulbs - $49.95 - Free Shipping
Ziza lighting is proud to introduce LED license plate bulbs for the MK5 that will not throw a bulb out code. These lights are direct replacement bulbs that install in minutes, there is no need to wire up fancy resistors or hack your factory wiring to get these to work.
Simply remove your plate light assembly, replace the factor incandescent bulb with our Ziza bulb, and re-install the plate light assembly. When installing bulbs, be sure to place the end with the large heat sink pointing upwards, this makes sure the brightest part of the LED will be shining down on your license plate.
If the bulb does not illuminate, remove the housing and reverse the bulbs position. LED bulbs have a polarity, so they must be installed correctly to illuminate.
Click HERE to order or for more information.
