Hi Jeff
I was aware the 3.0 uses the 312x25 but as I brought my A4 2nd hand does that mean the previous owner upgraded them? Did Audi install the 312x25 brakes on 04 cars onwards?
Currently only running the OE 16" rims but plan to upgrade to 18" later. It seems the B7 A4 calipers are the same as the B6 S4. I'm surprised the same caliper has clearance for discs size which are like 25mm bigger!?
What difference does the B6 1.8T caliper have vs B7 A4 2.0T?
Copied from a4mod website:
B6A4 1.8t- Same Caliper as B6A4 3.0
Front Rotor: 288x25
Rear Rotor: 245x10 or 255x12
B6A4 3.0- Same Caliper as B6A4 1.8t
Front Rotor: 312x25
Rear Rotor: 255x12
B6S4- Same Caliper as B7A4 & B7S4
Front Rotor: 345x30
Rear Rotor: 300x22
B7A4- Same Caliper as B6S4 & B7S4
Front Rotor: 320x30
Rear Rotor: 288x12
Thanks
J
Originally Posted by
Jeff
312x25's are off the 3.0. Stock 1.8's use 288x25's. But the 320x30 set will also fit.
