So I got a coolant leak coming from the rear flange. What a pain of a job! But I got it swapped out and the engine is staying cool now.
While I was doing the swap I made a major boneheaded error. At the rear of the engine there is an oil sensor. I believe it's a pressure sensor, but not positive. But you need to remove the sensor to swap the flange. So this swap took several evenings. One evening I had to move the car and forgot to repace that oil sensor. So even though the engine was on for no more than 10 seconds oil shot EVERYWHERE!
Prior to the swap I was stranded on the way home. So I drove it and would let it cool down if it got too hot. I also did things like shuting the engine off for downhill coasts.
When I refilled the coolant I used prestone orange dexcool 50/50 with distilled water.
So now I have several issues. I've thrown a solid CEL. My heater wont work at idle. My biggest issue is there is a slight rattle/vibration between 2000-2750RPM. It sounds like a heat shroud is loose but in the engine bay nothing is loose. I think it's coming from the top of the engine.
So now I have questions.
1) With this oil sensor. Was there any part in that oil sensor that might have shot out and are causing my rattle? I suspose I can find this out from the parts guy at the local audi dealer.
2) I've been doing some reading and am not 100% sure if I am okay to mix dexcool with the coolant that was in the car already. Should I flush and replenish with G12 or all dexcool?
3) How do I determine what codes have been thrown in the car? Does Audi use the whole solid CEL means emissions issue and blinking means a serious issue? I was thinking intially that having the engine on with the oil system open threw the code. But I've closed it back up and the code remains.
4) Why is my heat dying when I come to a stop? On my other car that means the coolant is low. But I just filled it. Could it be an air pocket? The car isn't over heating, but the lose of heat is annoying.
5) The rattle/vibration is obviously the most concerning issue. I'm praying I've not done any permenant serious damage to the car. The rattle does not seem connected to the turbo spool. The vibration is mild but noticable. It's only in that narrow RPM band. Thoughts on what it might be?
I know this is a lot of stuff. I don't expect someone to know it all. Thanks for any help you guys can give.
Much appreciated.
Mike
