Ever since I have put in my VEI boost gauge I have had problems with it. Has anyone else had problems that is running one? It will light up the psi and vac lights at the bottom and sometimes even show a 0 where the numbers are before I start the car but then it will show no numbers after the car is running. I can shut the car off and come back 10 minutes later and start the car and it will work then it could work every time that day then not work the next. I'm starting to get aggrevated with it, I have checked that the hose isnt pinched or something like that and it's clearly getting power fine since the lights for the little icons light up but no damn numbers appear sometimes. It is like a 50/50 chance that it is gonna work.
Winston, if you see this what is the deal?
