Results 1 to 10 of 10
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    Turbocharger insulation kit on gt2871r
    I just got finished installing a DEI turbocharger insulation kit on my gt2871r turbo.
    This consists of wrapping the downpipe in insulating wrap, and then wrapping the turbo with the same type of wrap followed with the reflective material on the outside.
    This is supposed to lower underhood temps, and probably other benefits that I am unaware of. Feel free to comment.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Turbocharger insulation kit on gt2871r
    Nice, are there any other benefits other than being able to "touch" it while its hot?
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Saint Cloud, Fl
    looks good so far, let us know how it performs
    instagram ------------> low_enforcement
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by biketsai View Post
    should spool a tiny bit quicker and keep things cooler
    - Clint
    Jan 19 2008
    You should wrap the manifold too for the best result.
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    just hope you dont get any oil leaks on that dp....FIRE
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    The wrap needs to be sealed other wise you will just end up causing the DP to crack, same goes for the manifold. The reason to seal it is because the wrap will trap moisture between it and the metal.
    Oct 30 2007
    Griffin, GA
    I might wrap the manifold in the future, when I take it off again.
    There hasn't been any oil leaks onto the downpipe since I've owned the car.
    If it traps moisture, wouldn't this moisture be evaporated as soon as the downpipe heats up?
    ** 2001 A4 TQM
    Jul 07 2004
    socal
    Quote Originally Posted by f15046 View Post
    yes, but it fatigues the metal which then cause it to crack. This has been an issue for a long time which is why the companies that make the product came out with a sealer that is applied to the outside of the wrap so moisture can not get between the wrap and the pipe.
    Product from DEI
    HT Silicone Coating:
    The HT Silicone Coating™ provides lasting protection for any hot surface up to 1500 degrees. We recommend the use of this coating with our exhaust wraps because it seals the material and provides lasting protection from oil, dirt and road grime. Don’t limit the use to exhaust wrap, this products works well on headers, blocks, starters and even on your grill at home.
    Heat protection up to 1500 degrees
    Seals and protects exhaust wrap
    Many uses around the home and shop
    One can enough for V-8 headers
    Oct 30 2007
    Griffin, GA
    I will look into getting some sealer then. Thanks for pointing that out. I'll prolly pick some up at Summit Racing on my way home on Monday.
    ** 2001 A4 TQM
