Results 1 to 9 of 9
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Lighting and Such..
    Okay so basically I am trying to do a huge overhaul on the interior and exterior lighting in my A4. Several things that I am looking at are replacing the sidemarker lights with LED's, but I need resistors for them. If anyone can help me understand the process that I would need to use to install them suckers. On the interior I found a thread so don't post anything bout that cause I got that covered.
    One last question is that I have standard shitty halogens and want to upgrade. Now would you recommend Xenon, HID, or (preferably for me) is there a bulb I can find to install there to give me a brighter light cause I have trouble seeing at night.
    One last thing is that can anyone tell me a place where I can buy LED's or festoons to replace my lights over my tag that dont need resistors and wont flicker and burn out.
    If you read this than thank you cause I need some help here and there. Any help or suggestions is greatly appreciated!
    Clear Corner mod scares me btw...
    Exterior
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings muffinman's Avatar
    Jul 01 2007
    Ask, USA
    Re: Lighting and Such..
    Quote Originally Posted by Turn10 View Post
    Exterior
    Try Osram/Sylvannia Silverstar Halogens... awesome halogen bulbs (what I used before my BiXenon retrofit) - very bright and white (for halogens). None of that blue coated bulb ish that reduces light output.
    2015 Audi S3 Prestige with Performance Package - on order
    2015 Audi Q3
    2009 Audi S5 Coupe - Tiptronic, B&O, Technology Package, Navigation, Carbon Atlas
    2009 BMW 328i
    2007 Audi A4
    FS: CPO 2009 Audi S5 - Tiptronic - Warranty - Seattle, WA
    Veteran Member Four Rings redlabel81's Avatar
    Nov 24 2007
    A4 1.8TQ 2005.5 + A6 1.8T 1998
    Tromsoe, Norway
    That or the Philips x-treme! Do not recommend doing the HID bulb in the halogen housing. I am currently running them myself and they throw light all over the place........
    PM Darren for a price on the DEPO Headlights if you don't mind the angel eyes.
    As for the licensplate light I have tried 5 different type of bulbs on my car and all flickered. Have now installed the resistor and it work great.
    Life is too short to drive ugly cars!
    Phantom Black B7 A4 1.8TQ Avant
    //BSR PPC stg 1, 98 Oct//BSR cat back//S-line front rebuild//S-line suspension//Supersport loweringcaps//Votex valence//S4 doorblades//RS4 mirrors//S-line roofspoiler//S-line door sills//LED interior//Hoen fogs//mTec 6000k HID//RNS-E//S4 grill//MMR HR4//H&R 8mm//Dectane HL//LED licenseplight//Euro RS4 steering wheel//Sonniboy "Tint"//RS4 rear sway//
    Senior Member Two Rings cfujikawa's Avatar
    Feb 04 2008
    HID and Xenons are the same thing. You can get a HID system and put them in your halogen lights, but like redlabel81 mentioned, it's not recommended. it's best if you have a projector lens. here's a thread with some more info...
    http://www.audizine.com/forum/showth...24#post2686824
    and you can try these for your license plates:
    http://www.audizine.com/forum/showthread.php?t=242172
    : 2017 Daytona Gray Pearl Q5 2.0T Premium Plus / Tech / Sport / 20" Rim Pkg :
    : 2007 Silver Acura TL Type-S :
    : 2013 VW Golf 4-Door TDI : *gone*
    : 2006 Quartz Gray A4 2.0T Quattro S-Line Tiptronic : *gone*
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    http://www.intellexual.net/hid.html
    the info on the above site is very useful, WRT HIDs.
    2006 Audi 2.0T quattro Tiptronic
    APR Stage 2+
    OEM+
    _______________
    2013 Passat TDI
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    thanks guys, i just need a little help now with the resistor install...
    Senior Member Two Rings rocchioj's Avatar
    Jan 15 2008
    Queens%2C%20NY
    I don't understand why everyone thinks it's so complicated to change the rear license plate bulbs. I bought these from hoen when I got my foglights. I got them almost a year ago and they've worked perfectly. No flickering whatsoever, no resistor and no bulb out warning.
    \http://www.hoen-usa.com/licenseplate.htm
    Feb 04 2008
    that's cause the hoen's are incandescent bulbs. no need to mess with resistors and such. it's a straight swap. which is why i went with the hoen's as well. but everyone wants the LED bulbs in there, and for that you need resistors.
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Ok so is there i DIY on resistors because I dont understand how to install them...
