Results 1 to 15 of 15
    Established Member Two Rings jaredsogn's Avatar
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Ebay FMIC piping
    Hey guys...just bought the ebay FMIC. I am searching to find the right intercooler piping for it. Can anyone point me to the correct set of pipes on ebay? I am looking for the one used in this writeup: http://www.audizine.com/forum/showthread.php?t=191938
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Re: Ebay FMIC piping
    Ha never mind guys. Think I found what I'm looking for: http://cgi.ebay.com/ebaymotors/2-5-T...5937QQtcZphoto
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    should have just bought the fmic with the s4 piping and saved yourself some trouble
    Oct 02 2006
    2001 Silver S4
    Watertown SD
    Yeah, I considered it. But I'm gonna follow Dr. Duct writeup. Looks like it fits pretty decent. I didn't feel like shelling out over twice as much to have the pipes basically "put together" for me. I'll make them work.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    did you buy them yet?
    i recommend 2" if you want to make it a clean install.
    iirc, duct is not running a front bumper support at all. 2.5" is unnec. just think of the intake tract - the fmic piping is not the bottleneck in the system ...
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Registered Member Two Rings
    Oct 24 2008
    Louisville, Ky
    I recommend AWE side mounts. But then I won't be putting a park bench wing on my vehicle, either. Both of these seem to take the car in a direction that is different than a 4 door luxury sport.
    I have seen front mounts that are well hidden, as well. I think those just cost less than AWE side mounts. THAT I can relate to. You can't argue against something that does the job within budget, and isn't fugly!
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Quote Originally Posted by 4RingsCircus View Post
    Pink is AWE and red is the EBAY fmic
    l gotta-- l gotta get
    a form from a scientist.
    Jun 02 2011
    Chicago
    does anyone have a link to the piping kit that will somewhat fit with the cxracing core?
    WTB: stock b5 s4 exhaust,stock driveshaft,stock rear sway bar
    Senior Member Three Rings haggard69er's Avatar
    May 20 2007
    Alligators
    pittsburgh
    I bought the two kits listed below, was able to retain fog lights, and also I had enough piping left over to make bipipes :)
    2.25" Mandrel Bent Aluminum Piping Kit
    2x Straight Aluminum Pipe
    2x 45 Degree Aluminum Pipe
    2x 75 Degree Aluminum Pipe
    2x 90 Degree Aluminum Pipe
    6x Straight Silicon Hose (BLUE)
    2x 90 Degree Silicon Hose (BLUE)
    16 Matching Stainless Steel T-bolt Clamp
    2.25" O.D. Mandrel Bent Universal Aluminum Piping Kit
    6 Pieces of Polished Aluminum 90 Deg. L Pipe
    7 Pieces of Silicon Hoses
    14 Matching Stainless Steel T-Clamps
    Veteran Member Three Rings z00lander's Avatar
    Apr 10 2010
    VW Atlas family mover
    everett, wa
    How much did you spend?
    Apr 10 2010
    everett, wa
    You have to get rid of the bumper support? Wtf. Well to each their own I suppose.
    Active Member Two Rings 01SPLIFIN's Avatar
    May 01 2012
    FJ80, B5-S4
    Santa Cruz, CA
    some guys keep there front lower grills. on i know most people have said u cant re-install the fog lamps, but being in the mountain i need em. is there any way i can keep em on with the front mount intercooler ?
    Oct 27 2011
    TOYS
    Philly Suburbs
    Quote Originally Posted by 01SPLIFIN View Post
    Of course - custom piping...
    Veteran Member Four Rings The_Auto_Tech's Avatar
    Nov 30 2010
    2001 Audi allroad 6MT
    Des Moines, IA
    Quote Originally Posted by z00lander View Post
    You don't have to get rid of it. You simply need to trim a bit of it.
    2006 Ford F-250 Amarillo Edition - MOARYLW - Mine
    2001 Audi allroad 6MT - Wife's
    Previous - MKIII Jetta, MKIV Jetta x2, MKIV GTi, B5.5 Passat x3, B5 A4 x2, B5 S4 x2, and tons of Domestic/Japanese crap
    - Cody T.
    Veteran Member Three Rings zrider91r's Avatar
    Jan 06 2012
    California
    people keep the bumper support. I will be when I do this.
    engine, K04s and a JFonz stage 3- coming soon!
