Results 1 to 4 of 4
    Junior Member Two Rings dRopT's Avatar
    Apr 30 2008
    07S-Line,19Tiguan
    north jersey
    Wheel Spacer question
    I have an 07 S-Line with the Titanium package, and was wondering what size spacers I need in the front and back to get the wheels flush with the fenders. I plan on lowering the car soon with coilovers, and I am not sure if I need spacers to lower it. Any tips or comments would be appreciated, thanks.
    Established Member Two Rings Ibis-Titanium's Avatar
    Jun 01 2008
    Grand Prairie, TX
    Re: Wheel Spacer question
    I have an '08 S-Line w/ Ti package(on Ti wheels). My car is dropped on Eibachs, and I'm running 12mm H/R spacers at rear, and 8mm H/R spacers up front. The spacers gave the car a much more aggressive stance, and made the view of the rear much "fatter". I personally wouldn't go any bigger than 12mm's on the rear, or you will likely have rubbing issues with the factory Ti wheels, and 235/40/18 tires(if you go any lower than 25 1/4" ground to fender).
    PM sent...
    Former: '08 Ibis White Ti-Package A4 2.0T Quattro 6MT S-line. DTM Front/ APR HPFP/ Unitronics HPFP Software/ AWE FMIC/ RAI 3" DP/ Okada Coils/ RAI Catch Can/ Vast Clutch/ BFI Snub/ TT S-line FB Steering Wheel/ OSIR/ Eibach/ 18" GM VMR V710/ Michelin Pilot SS/ JHM Short Shifter/ S4 2Pc BBK/ Blackout Rings(F&R)
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    my sig, on bilstein pss9's 10mm front 15mm rear, not flush but close. Do have a VERy small rubbing issue in rear but that's because the fender liner is broke and hangs...
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
    Senior Member Two Rings vroompshert's Avatar
    Oct 14 2007
    Irvine, Orange County
    Quote Originally Posted by Ibis-Titanium View Post
    I have an '08 S-Line w/ Ti package(on Ti wheels). My car is dropped on Eibachs, and I'm running 12mm H/R spacers at rear, and 10mm H/R spacers up front. The spacers gave the car a much more aggressive stance, and made the view of the rear much "fatter". I personally wouldn't go any bigger than 12mm's on the rear, or you will likely have rubbing issues with the factory Ti wheels, and 235/40/18 tires(if you go any lower than 25 1/4" ground to fender).
    PM sent...
    How is your ride with the Eibachs? I have 10mm/15mm spacers, front and rear respectively. I'm looking into lowering soon just don't know with what yet.
    Thanks,
    '08 Audi A4 2.0T Quattro MT6 / S-Line / Titanium / Navigation/ Convenience Package/ Bluetooth /19" Piano Black Rotiform MIA's w/ Hankook Ventus V12 Evo -235/35/R19/ H&R 10mm rear Spacer/ EVOMS V-Flow/ 6000k HID Fogs/ 6000k D1S
