Results 1 to 4 of 4
Thread: oil pan leak
    Dec 26 2007
    1999 Panoz AIV roadster
    New Market, MD
    oil pan leak
    A friend of mine has a 2004, A6 with about 50-60K miles on it (and factory turbo engine I think?). Anyway, she has an oil leak at the oil pan, took it to the dealer and they said $1,000 to fix. Took it to another dealer and they said $600 but that they go bad all the time and she'd be back next year for the same thing. WTF? I'm surprised a dealer service person would say that. What's the story on this? Thanks.
    1999 Panoz AIV
    Senior Member Two Rings African2.7T's Avatar
    Dec 18 2007
    B5 S4 Laser RED
    PA
    Re: oil pan leak
    i never heard of that been sumthing that goes bad i'm sure if she scraps alot of driveways then that would be true.
    MK4 GLI Blue lagoon
    B5 S4 Laser RED
    Past Rides
    C5 A6 2.7T
    B5 S4 Santorin Blue
    MK4 JTI VR6 Money Green..lol
    Veteran Member Four Rings audirs's Avatar
    Mar 22 2005
    Kitchener, Ontario
    Re: oil pan leak
    FYI, a passat 2.8 oilpan will fit on a 2.7T. it will be cheaper to buy a used passat 2.8 pan and bolt it to the 2.7. i cracked my oil pan, and my buddy fitted one from the 2.8 up. and ya i dont think an oil pan his considered a wear and tear item?
    Q5 3.0T S-line
    VW Tiguan R-Line
    A6 2.7T AWE Stage 3
    Coupe Quattro
    Apr 18 2007
    ny
    Re: oil pan leak
    Is it leaking at the gasket or does it have a hole in it? If it's the gasket, all you have to do is replace it and it def won't cost $1,000
