Results 1 to 16 of 16
Thread: COLD S4
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    COLD S4
    My heat will only stay warm for about 3 minutes and then the air becomes cooler. My car warms up proprerly, but when driving on the highway my water temp drops to the cold side about a 1/4 of the way to cold. I was wondering if it is ok to be driving it like that?I'm not sure if this is my coolant temp switch or thermostat. Flushed the coolant twice in the past 3 weeks due to a broken T that exploded by my reservoir tank.
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Oct 12 2008
    2002 S4
    San Jose
    Re: COLD S4
    well, i would be much more concerned if it was an overheating issue...i think its something to look into, but keeping an engine cool usually isnt bad ;)
    Feb 17 2008
    Ottawa Ont.
    Re: COLD S4
    uh. its not great either.
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: COLD S4
    Quote Originally Posted by s42k5b View Post
    Hey, you going tonight?
    l gotta-- l gotta get
    a form from a scientist.
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: COLD S4
    thermostat is stuck open
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Re: COLD S4
    did you do a t-belt job yet? if so, did you replace the thermostat?
    Veteran Member Three Rings Tugboatguy's Avatar
    Apr 08 2008
    07 S4 , 04 A4 1.8T Avant , 05 S4 VF SC
    New Westminster BC
    Re: COLD S4
    It's your thermostat , and no Don't drive like that.
    Aug 01 2008
    Montenegro
    Re: COLD S4
    I have a similar problem. My water temp gauge climbs and drops. I guess it's thermostat problem...
    Is my car running a bit slower when the gauge drops, or is it just my imagination?
    p.s. My B5 S4 has 54k miles on it so no TB job has been done yet. A couple more thousands and I'll turn it to a dealer for the job.
    May 31 2008
    New York
    Re: COLD S4
    Quote Originally Posted by TommyGunn View Post
    yupp you?
    May 31 2008
    New York
    Re: COLD S4
    Quote Originally Posted by RedRocketS4 View Post
    T Stat was replaced when timing belt was done.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: COLD S4
    Sounds like it broke again.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jun 14 2007
    2000 S4
    Connecticut
    Re: COLD S4
    yeah a cold engine will usually run rich causing shitty gas mileage and a cold motor doesnt run as efficiently as a warm one. i had the same problem with mine i would notice it on long trips prior to the Tbelt job..
    Aug 06 2008
    Canadia
    Re: COLD S4
    mine did the exact same, you need a new t-stat.
    you can replace it without removing the belt, its not that hard, but it requires cranking the engine over by hand and shuffling the timing belt away from the block about 3/8" to give you just enough clearance to remove the housing and t-stat.
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Re: COLD S4
    Quote Originally Posted by cavlovic View Post
    You need to get the timing belt service done either 105,000 miles(recommended by audi, should be 85,000) or 6 years.
    Better get that done soon.
    Aug 04 2008
    CO
    Re: COLD S4
    I would not wait any longer. Your rubber is 8-9 years old, rendering it drier and more brittle than I'd be comfortable with. IIRC, Audi does state 7 years as the limit...
    Senior Member Three Rings Muck_and_Grind's Avatar
    Jun 09 2008
    2001.5 Audi S4 (on stands), 1989 Grand Wagoneer, 2007 B9 Tribeca
    Lodi
    Re: COLD S4
    dont be a puss. who needs a heater anyways. oh wait i live in california.
