Results 1 to 16 of 16
    Jan 04 2008
    Cincinnati, Ohio
    Miles to empty--after fill up
    So I always look to see how many "miles to empty" the car shows when I fill up. Typically it is anywhere from 450-480. However, the past few times I have filled up, it's been anywhere from 380 - 450. What causes such a great fluctuation? how accurate is this system? I never had this big of a variance on my old Jetta.
    Mar 17 2008
    2007 A4 2.0T Tip
    arlington, Va
    Re: Miles to empty--after fill up
    i could be totally wrong but my assumption is that the computer will calculate the "miles to empty" based on your current "avg mpg". For instance, if you just got done driving on the highway for a good amount of time and you have a high "avg mpg" then the car assumes that you can travel x amount of distance (longer distance based on high avg mpg) based on that current avg. If you were just driving around town spirited getting a lower "avg mpg" then the computer assumes you will only be able to make it y amount of distance before fill up, thus showing a lower "miles to empty"
    I no way do i know that this is true just my assumption.
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    i only got 280 out of my last tank from odo reading. i was freacking sad about my 320 on my b6... now it's worse. this is from full till gas light comes on. my miles to empty reads alot more on a full tank so i'd imagine it's off
    Mar 03 2008
    2005.5 B7 A4 2.0TQ 6MT
    Washington
    I've only filled up three times. However, I got 361 miles out of one tank and 356 out of the other (I'm on the third tank right now). Each time, the "miles til empty" has read much higher than that after filling up. About 450-480 each time. I haven't been tracking it, so I'm not sure.
    I got 24.0xx on one tank and 23.9xx on the other when I calculated the mpg myself. According to the mfd I was getting right around 29mpg. So it's about 5mpg higher than actual.
    2005.5 A4 2.0TQ 6MT
    Black on Black
    Loaded
    "Brown Chicken Brown Cow"
    Mods = 0
    Apr 04 2008
    2006 Audi A4 Quattro
    South East Connecticut
    I'm pretty sure it actually states in the owner's manual how it's calculated. As said above, it will definitely fluctuate a lot depending on the type of driving (and will affect miles to empty if you're driving hard just before filling up) My car reads out about 500miles to empty when I fill up but every loaner I've had reads out in the high 300's/low 400's. After driving the loaner for a day that miles to empty goes up to close to 500 again though. I'd tell you how my car is doing for mileage but it just had a fuel pump replaced and my mileage has been shoddy for awhile :o I don't think I've ever gotten the full 500 miles from a tank because I get on to surface streets and somehow my right foot gets pulled to the floorboards...it's a disease, I tell you!
    Oct 01 2007
    Location, Location, Location
    I get about 280 as well. It shows about 450 when I fill up.
    Veteran Member Four Rings Geoffafa's Avatar
    Aug 31 2007
    The Big Blue Bitch and her mess
    Miami
    when i fill it shows like 340, i end up with 370... makes sense? i think not
    F.T.W.L.T.B.D.W.I.C.T.W.
    IG | @fukn_fafa
    So air is like the hot girl that is no fun in the sack, and good coils is the cute girl that is crazy in the sack. -chrislane
    DUH! an Audi
    los angeles, CA
    i dont get that much gas mileage, i seriously think something wrong with my bucket!
    Apr 06 2007
    Arcadia, CA
    I get 300 on average only =(
    But it all depends on driving style.
    07 B7 A4 Quattro Manual Sline.
    APR Software | Ecodetuning Testpipe | Milltek Exhaust
    RS4 Rear Sway Bar | ECS Snub Mount | AWE Boost Gauge
    Forge DV | PSS9 Coilover | Hartmann RS4 Replica with Falken 452
    Jun 05 2007
    Phillips Ranch, CA
    I get about 350~380 regularly, but I did just get 425 last tank. (btw I am Quattro as well.)
    Veteran Member Three Rings jimmya4's Avatar
    Aug 21 2008
    A4 b7
    The OC/ Boulder, CO
    theres plenty of difference between manual guys and auto too. you can get better mpg with a stick, but usualy (including me) you will get worse just from having fun driving one ;) mine says like 360 every time i fill up but havent actualy done the math
    2005.5 Quartz grey A4 Quattro 6mt/ REVO stage II
    Senior Member Three Rings Turn10's Avatar
    Jul 27 2008
    2007 B7 A4 2.0T
    Atlanta
    Average around 350-400, I drive on the highway and average 50 in residental so I maintain high MPG.
    When life passes you by, downshift.
    Tri-State Southern Audi Chapter
    http://www.audizine.com/forum/group.php?groupid=14
    Veteran Member Four Rings elwigglero's Avatar
    Sep 04 2008
    B7 S4 DTM, B7 A4 2.0T Ti
    Lansdale, PA
    Has a lot to do with the time of year. Cold weather brings gas additives that hurt mileage. If you're in a part of the country that has seasons that is.
    Jan 01 2008
    Long Island NY
    get like 300-400
    Veteran Member Four Rings gaede's Avatar
    Jun 06 2008
    fourbanger
    Carlsbad, Ca
    LOL OWNED!!1
    Veteran Member Four Rings vtracer20's Avatar
    Apr 14 2008
    Milton VT
    the highest i got was like 580 to being read out on the dash...but that was after filling up doing a tank on the highway, 31mpg was the actual measured, showed like 32/33mpg on the computer.
    2007 A4 S-Line / Ti Pkg / Quattro / Bilstein Pss9 / JHM Short shifter / GIAC X+ chip / RS4 rear sway bar / 20% rear tint / 10mm front 15mm rear spacers / Forge DV / DTM CF replica rear lip spoiler / DTH CF roof spoiler / Cupra R front spoiler (not on) / Infinity BasslinkII sub
    looking for: CF front lip / S4 alum mirror hosing
