Results 1 to 19 of 19
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    Angry kind of fraustrated
    i have this huge ugly license plate mount on my front bumper, to take it off would leave three HUGE holes in my bumper from there the screws go through to mount it. I'm undecided whether to take this huge ugly thing off, clean up the front end a little bit, and reveal huge holes. or leave it on and ignore it until i get a new one (could be a while) any idea's, alternatives, Etc.?
    Veteran Member Three Rings bronz's Avatar
    Sep 21 2006
    Lyons, IL
    Re: kind of fraustrated
    what color is your car?
    2014 Audi S4 DSG
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    I say take it off, my Golf you can barely see the holes...
    Sorry I have no real good pics
    Veteran Member Four Rings belinko's Avatar
    May 09 2005
    Audi 1.8T QM
    Encinitas, CA
    I removed my front plate and machined some aluminum plugs/caps. It looks way better than having an ugly plate attached. $.02
    1.8L, JE pistions, IE rods, APR stg3+, GT28 Turbo, Setrab, ER comp. FMIC, APR HFC, Milltek Cat-back, APR 91, 93, 100 - CM FX 300, CM 240 LWFL, JHM 4:1, AMS SS, RS4 Motor Mounts - 355mm Alcon 4 pot, 300mm Alcon S4 - Stasis/Ohlins MS, Hotchkis Front and Rear, Stern adj. CA Front, 034 adj. CA Rear - 18x8.5" Work CR Kai wheels, NT-01 & Dunlop Z1 star spec - RS4 Front bumper and grill, Tow Strap, RS4 E-codes - SPA Technique Dual Digital gauges Oil & Water temp, Oil & Boost pressure, RS4 Door Handles
    Senior Member Three Rings edwardabodnar's Avatar
    Mar 08 2008
    Miami
    Take it off and get your self a Euro plate, make sure its from Ingostadt (IN), and double sided tape it on the front.....sexy time
    Registered Member Two Rings Sick_Boy's Avatar
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    im sporting the holes. and what makes it worse is the top hole is off center but i still think its better looking then a big ass license plate on the front of the car
    Oct 06 2008
    2001 Audi A4 1.8 T
    black bumper, the holes are about 3/8".
    not to sound rude or anything, but i'll pass on the euro plate. its just not my thing.
    maybe find some black plastic caps?
    Oct 11 2008
    01 A4 1.8tqm
    St. Charles IL
    yeah just go with some caps being a black car you wont notice the caps really
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    I guess i just got super lucky because my front bumper doesn't have those holes. Apparently there has never been a license plate bracket on there, which is cool considering the car spent most of its life in california where you need to have a front plate.
    {99.5 Avant}
    Senior Member Two Rings UberA3's Avatar
    Jul 28 2007
    Las Vegas
    http://www.bumperplugs.com/ Look much better than a hole
    2020 SQ5 Quantum Grey - Sport Package - Black Optics - Cete Controller - 034 ECU/TCU flash - AWE Exhaust, Intake, Intercooler
    2007 Misano Red A3 - DSG 2.0T - K04 - S3 body kit
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    I know what you mean about the holes. My front bumper has 3 of those big ones from the mount i pulled off and 2 more small ones that hold the plate. Fortunately, my required front plate covers all of it
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    My solution:
    Get some Crayola Model Magic (its this foamy clay) that is available anywhere. You just roll 3 balls and shove them into the spot, wait a couple hours for them to dry, then take a touch up pen and paint it. Worked fine for me!
    (shows a little white because I painted them before they hardened, but you get the idea.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Quote Originally Posted by biketsai View Post
    My solution:
    That's a neat idea. I think I'm gonna give that a whirl. Worst case scenario I use the euro plate I already have to cover it up.
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    I just filled the holes and painted them. it doesnt get much easier than that!
    "slow is smooth and smooth is fast"
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    just fill the holes and use touch up paint, will look a lot better lol.
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Veteran Member Four Rings le91688's Avatar
    Jun 20 2008
    2000 A4 2.8QM
    Pordenone, Italy
    i think im getting a german plate to cover mine up
    __________________
    Veteran Member Four Rings rocky.ca's Avatar
    Aug 24 2008
    yah, just cover it up with a euro plate
    Oct 30 2006
    B8 A4 Avant 6spd
    I just zip tied my front plate to the lower grille on my S4 bumper, not taking my filler plate off. Dunno what ill do when I get a fmic though =/.
    -18 718 GTS
    Feb 12 2004
    2018 M3 CS, i3 REx
    Orange County CA
    I had the same problem on my B5. I just kept the plate on to avoid tickets, but I live in CA. Looks better than holes IMHO.
    Former:
    BMW F80 M3 CS
    BMW F80 M3
    BMW I01 i3 REx
    BMW F30 340i M Sport ZTR
    Audi B7 S4 25Quattro
    Audi B5 A4
