no its not the fog relay. the fog relay if you are staring at your glove box with it tilted all the way down, reach up on the right hand side and then twist your fingers towards your face. that is the fog light relay. it sits inside of a black holder with a long 'finger' that holds it into the pins. the finger is only as big as the relay is without the pins on it, so you have to pry like hell to get the finger down, then get the relay out, and while all of this, the finger is attached to a plastic holder that is taped and attached to the wiring harness so it can not move.
i ended up pulling my relay harness and relay out of the holder and did the fog light mod, then shoved it back into the harness and left the holder and finger thing off.. i havent had any problems at all, its never even attempted to come lose. it was too much of a bitch to get a relay that goes into a holder that is only as big as the relay, minus the pins. my pins kept getting bent to hell from trying to put it in sideways, then swing it down so it would seat right.
