Results 1 to 4 of 4
    Established Member Two Rings xlacrosse's Avatar
    Sep 30 2007
    2007 Audi RS4
    Brooklyn, NY
    How to Bleed Clutch?!?
    Does anyone have a link to a DIY on the procedure to bleed to clutch on a B6/B7 ???
    I cant for the life of me find the bleed valve on my RS4.
    Any help would be greatly appreciated
    2007 Mugello Blue RS4
    Milltek Exhaust Non Res| KW V3 Coilovers | H+R 10mm Spacers | Alcon 6 Puck Clutch
    Past Rides
    2007 BMW Z4 ///M Coupe
    2005 BMW ///M3
    Established Member Two Rings eweu's Avatar
    Aug 25 2008
    Silicon Valley, CA
    Re: How to Bleed Clutch?!?
    It's above the left side driveshaft. You have to remove the heat shield around the driveshaft to get at it, but it's right there.
    Sep 30 2007
    2007 Audi RS4
    Brooklyn, NY
    Thanks for the reply. I figured that was it, but I couldn't really get a tool small enough to remove the heat shield over the driveshaft.
    Past Rides
    2005 BMW ///M3
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    Could someone tell me the point of this?
