Results 1 to 20 of 20
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Cold Air intake install
    I recently bought an ITG filter i want to put it in as my intake but would like to take out the airbox and make my own aluminum heat shield between it and the motor. Any ideas on what to do with all the sensors atop the current stock airbox?
    I want to mount the filter straight onto the MAF. Is this going to be a PITA or not too bad because I can just put it inside instead the airbox than.
    Established Member Two Rings S obsessed's Avatar
    Sep 27 2007
    North Dakota
    Re: Cold Air intake install
    Those sensors are the ignition control modules and they need to have the aluminum heat sink attached to them. You could make a new heat sink or just cut the one out of your stock airbox. The stock airbox on these cars with the darrintake mod seems to be the way to go. No one has really seen any real advantage of doing what you are thinking.
    2001 s4 6sp stage 3
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    I run stg 3 with a stock air box and stock air filter, it works great, I used to use an ITG filter it is nice in all but I got oil from it in my MAF. IMO just cut or drill you stock box and that is it or try teh Vast X-1 intake . Good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    Quote Originally Posted by S obsessed View Post
    Why do they need to have the Aluminium heat sink?
    Sep 27 2007
    North Dakota
    they get warm. It is common for ignition control modules to be on some sort of a heat sink. Not using heat sink may never pose a problem but it is not a bad idea.
    2001 s4 6sp stage 3
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    looks like you found your misfire problem adam...
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Aug 06 2008
    Canadia
    I would stay away from any of those cotton gauze and foam filters. they don't trap the fine dust coming into an engine and that dust rounds the edges of the turbines on the turbos. that will result in less boost (or in our case, the turbo working harder to produce the same boost and sooner failure).
    stick with a high quality paper filter, eg. not fram.
    Mar 23 2008
    Tri State aRea
    Quote Originally Posted by MacDaddy View Post
    K&N? i thought paper wasn't as good because it absorbs moisture and such. What other brands make good quality filters if i should use the ITG?
    Veteran Member Four Rings S4 in_lowplaces's Avatar
    Feb 09 2006
    2021 SQ8, 2000 AWE stg 3 s4, 2012 CTSV 730Whp, Sold: 2000 Stg2 S4 revo,Totaled: 2000 Stg1 S4 APR
    Huntington Beach
    lots of people have open element filter. Lots of stage 3 guys do, the ones that homebrew they're car.
    I've used K&N for years and never had a problem. I threw it out and just got the paper filter. its up to you. as long as you have filtered air coming in your good. goodluck
    2021 Ocra blk SQ8 - Daily
    2011 CTSV coupe 730 WHP - Garaged
    2000 Silver B5 S4 AWE stg 3 - Garaged
    2002 Silver b5 s4 stage 2 revo - Totaled
    2001.5 silver apt stg 2 b5 s4. - Sold
    Jun 14 2007
    2000 S4
    Connecticut
    i cut the entire bottom of my RS4 Intake apart to get more air.... should i have done that being that it was so expensive? probably not LOL. but it makes a shitload of sound you can usually only hear it with either the windows down or if you're in an enclosed area like a parking garage..
    Veteran Member Four Rings SLC_S4's Avatar
    Jul 15 2007
    2001.5 S4
    Utah
    I'm stage 3 and use a drop in ITG panel filter with a stock RS4 airbox. I've never had problems with oil on the MAF sensor or any problems with my turbos. I clean it just about every oil change. You really just need to be sure you don't over oil the filter or use it dry. Also be sure to use a high quality filter oil as well and you should avoid having problems.
    -Seth
    APR Stage 3 - APR Stealth exhaust - APR downpipes - APR Bipipe - APR snub mount - AWE side mount intercoolers - AWE LWFW - RS4 clutch - ITG panel filter - JHM Shifter - Startup Racing Vogtland GT coilovers - Stern adjustable control arms - Fiber Images vented carbon fiber hood - Fiber Images carbon fiber fenders - Recaro Style Topline seats - A bunch of other stuff I can't remember
    Mar 23 2008
    Tri State aRea
    is there a diy for installing it inside the airbox?
    Aug 06 2008
    Canadia
    Quote Originally Posted by dennisS4 View Post
    its only going to absorb moisture if you do that dairintake mod and drive trough a puddle or very rainy weather If you live in a place like i do where it rains allot I would leave the airbox stock.
    K&N will tell you their filters are fine because they don't want to scare people off if they know it will make your turbo look like its sandblasted. I've seen it happen to lots of 6.0 ford diesels (almost every truck with a K&N or similar). I realize a diesel dosn't have a throttle body and a 6.0 engine will move more air than a 2.7L, but the fact of the matter is it will still happen it may just take a little bit longer on our engines than it does on the ford diesel.
    If you really want to run a high flow filter, I would use it on the track only, for DD i would use a paper.
    Mar 23 2008
    Tri State aRea
    We'll I already have the darintake mod done. I did it by cutting 3-2" holes and dropping sink strainers in and bolting them on. These screens should keep most contaminates out. These screens are not going to keep the water out though.
    Mar 23 2008
    Tri State aRea
    Our cars come equipped with a K&N panel filter from the factory. I'm not sure if this is the one your referring to or just K&N is general??
    Aug 06 2008
    Canadia
    you sure? I've never heard of that, and its strange they wouldn't put a sticker on the airbox saying it has a re-usable filter.
    All vw and audi come with a non reusable paper filter, there is no manufacure of cars that I know of that came a oil type filter element.
    Maybe when you bought it someone had already switched the filter.
    I know this for a fact
    For a good high flow paper use an aem dryflo, those are very good filters and you don't have to sacrifice the filtering capacity to get more airflow. And they are reusable
    Veteran Member Four Rings KompMan420's Avatar
    Sep 04 2005
    2001.5 Audi S4
    Tampa, Florida
    I'm stage 3 with Darintake mod. I had the K&N drop-in filter at first. Tested the flow of that setup against my now stock paper filter showed ZERO gain from MAF readings. Save your money.
    SOLD - 2001.5 Audi S4 Twin Turbo ~ 450hp
    Mods - AWE/GIAC Stage 3 | AWE Intercoolers | STaSIS Coilovers | RS4 Clutch | 3" Borla Cat-Back | ASP DTS | JHM Solid Axles | "Piggie" downpipes | Neuspeed SS | AWE Pedals | IceLink for iPod | 710n DVs | M3 Spoiler | LM Reps 18x8.5 Satin Black w/red Time Attack
    www.NJSRealty.com
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Quote Originally Posted by KompMan420 View Post
    I second that, the stock airbox is fine witht the oem filter.
