Thread: Bent Rims
    Oct 17 2008
    2006 A4 S-Line 2.0T Tiptronic
    Ohio
    Question Bent Rims
    Any one else had issue with bent Audi oem rims? I have the factory 18s for the S-line pkg, nailed a massive pothole on a curve only about 20-25mph. thought i was ok but over the last 2 months im pretty sure it wore a flat spot in my tires. i can hear it now, i took it to a tire shop and when the spin the wheels you can see both passanger side rims werent prefectly round anymore.
    there is a shop nearby they can supposedly fix most bent rims, takes a few hours a piece he said, about $75 a rim. so im gonna try it out on monday...
    Anyone bent one and had it fixed ok? did it toast your tires driving on it? im also worried that the vibration will cause premature wear on the struts.
    thanks all
    Veteran Member Three Rings Zebman's Avatar
    Dec 25 2007
    '06 A4, 08 R6s
    Morgantown/Hurricane, WV
    Re: Bent Rims
    When you saw the wheel was out of round, did they still have their tires on them? The tire may be disformed, not the rim. You may have lucked out. The real way to tell if a wheel is bent is to put it on a balancing machine without tires. If the weights required are astronomically high on either side, it's safe to say it's bent.
    2006 A4Q 6MT Arctic White - StageII++
    STaSIS SS Coilovers, EVOMS Intake, APR 93, OZ Ultraleggeras 17x8, APR Exhaust w/034 HFC, GSG Intake Pipe, AWE Front Mount, APR HPFP.
    2008 R6s
    : Racebike, don't feel like writing it all out.
    I don't get on Audizine anymore, so if you need me... sorry.
    Oct 17 2008
    Ohio
    Re: Bent Rims
    everything was still mounted, it was up on a lift spinning one tire made them all spin. So we were looking on the inside of the rim where it meets the tire.
    they guy at the shop seemed pretty cool, so hopefully if it wasnt the rim he would tell me and not charge me. im assuming he would tell when he put it on his 'super-duper-rim-fix-o-matic' ;)
    oh, and they did balance them for me but he said the worst was like less then .5oz out of balane? .. im not sure if thats a lot or not.
    one more thing... where do you guys get the Alignments done? the dealer?
    Dec 25 2007
    '06 A4, 08 R6s
    Re: Bent Rims
    The dealer is the smart place to go because they have the appropriate tools. Me and my buddies at a local NTB winged it on my car. The directions for the front alignment said it required some special VAG tool; we said fuck that and got a crescent wrench lol. The rears anybody can do.
    2008 R6s
    Oct 17 2008
    Ohio
    Re: Bent Rims
    what does the stealership normally charge? your 1st born or just a left arm? ;)
