Overall the kit is solid. Though it can be improved upon. When the calipers are installed on the brackets the hand brake lines are too short. I had to break the plastic that holds the hand brake line in the control arm so that I can pull on the line to have it fit onto the caliper. Also the fact that you have the shave down a bit of the upright to have one of the bracket bolts fit in was a minor inconvenience. Now onto the stopping power. I brought the car up to 130 or so and went about 3/4 brake to see how quickly the brakes shave speed. The car Stops really quickly. (Mind you I have front S4 2piston brakes) I recommend the kit to anyone who wants to do the work. It took me a few good hours to install taking my time on a lift. I just wish someone made a bigger pad to cover the entire rotor. I'm running Hawk pads front and rear.
Teaser to my S4 OEM BBK write up.
