Results 1 to 25 of 25
    Veteran Member Four Rings KPC1.8TQuat's Avatar
    Mar 20 2006
    2003 A4 1.8T Quattro, 2006 Triumph Daytona 675
    North Shore, New England
    Is it ok to run winter tires already?
    So my stock B6 needs new tires. I was planning on going with these Bridgestone Blizzak LM-25 215/55R16
    Tire rack says they are H rated which is good to 130 mph, which is the same as what came with the car. My driving is about 70% highway 30% town. I just want to know if it's ok to start running a winter tire while it is still dry out.
    Thanks
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Re: Is it ok to run winter tires already?
    what are winter tires? ;-)
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    I'm sure it is with the weather still cold, especially in new hampshire. Either way i don't think anything lethal is going to happen even with driving winter tires in the summer. I would say go for it if you NEED new tires now.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Veteran Member Four Rings 4Rings3Liters's Avatar
    Jul 04 2008
    York, PA
    They will provide less traction in the dry but you'll be fine.
    Mar 20 2006
    ^^^ That is the coolest avatar on this forum.
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    You should be fine, I am switching to mine the top of November. Being wet isn't the main factor for winter tires, they work better at colder temperatures whether it is wet or dry. The hotter it is the less traction you will have
    Mar 20 2006
    Yeah, I don't think we're getting above 50 from here on in. Also it's been in the low 30's at night and in the morning when I leave for work. I just wanted to make sure I'm not going to hurt anything.
    Thanks.
    CO
    I usually follow the "rule" that the temps need to continuously be below 50 degrees F. It hasn't been getting much about that here in MI so it's almost time.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    Dec 08 2006
    Jersey
    Avg. daily temperature is in the 50's this week and seems to only be getting colder
    Veteran Member Four Rings eurogruppe's Avatar
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    you'll be ok. i drove on my 18" avus wheels with pirelli snowsports for a month in august while my rs4's were getting refinished
    Mar 20 2006
    Ok, cool.
    Thanks.
    Veteran Member Four Rings LampyB's Avatar
    Apr 25 2007
    MA
    when i was a poor college student i drove on my michelin alpin winter tires year round for two years. never had a single problem, and my mpg was actually very comparable. even if it does get above 50 degrees there isn't anything to worry about. the only problem i can see is just putting more miles on them than you normally would.
    Custom Trunk Badges For Sale!
    | 2004 A4 USP 1.8TQ | 6SPD | GIAC 1+ | APIKOL | HYPERBOOST | FORGE TIP | NGK | 20% TINT | VMR | OFE SS | PODI | N249 Delete |
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    They burn off a little quicker..but I doubt you would really notice it.
    High speed Ferrari movement...
    Jun 05 2008
    2021 RS6
    Cleveland, OH
    yea as long as the tread isn't too soft like it is for blizzaks, then ur tirewear should be ok, althought it will still wear a little quicker just not as bad.
    You will notice that the winter tires will be a little noisier in the warm climate tho
    Veteran Member Four Rings widgget's Avatar
    Dec 18 2007
    nj
    you'll be fine.
    where in nh are ya? i'm in the wolfeborro / lake winni area.
    Mar 20 2006
    Quote Originally Posted by widgget View Post
    you'll be fine.
    Plaistow, down on the southeast/Massachusetts border. You owe me a ride in that BT tip dude, you get that boost leak worked out yet?
    Veteran Member Four Rings Mark's Avatar
    1959 MGA 1600
    Chocolate Land, USA
    just got a set of dunlop winter sport 3d's
    -Mark
    1987 5000 CS TQ 2.2T I5 - No more . . .
    2002 Denim Blue A4 1.8TQMS - RIP
    2005 Ebony Black Pearl allroad 2.7TQMT6
    Kinda stock . . . Tinted, H-Sport Sways, HP-2 Calipers, RNS-E, Bluetooth, and iPod/Sirius combined
    Got Vag-Com?
    Feb 17 2004
    Sterling, VA
    Quote Originally Posted by Mark View Post
    I hope they last for you. Mine lasted 13K miles. I put them on in October of 2007 and had to remove them in March of 2008. They had 3mm of tread left with even wear.
    I think I'm going to try some Blizzak LM-25 this year.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    1959 MGA 1600
    Chocolate Land, USA
    Quote Originally Posted by Daft View Post
    Yeah, I had a set of m2's on for the last few years. Have to make sure you don't run them when it's warm outside, otherwise they get burned right up. Probably got around 30k+ on them . . . on my second set of summer tires too. Whatcha gonna do?
    -Mark
    Got Vag-Com?
    Jan 16 2007
    Wetzlar
    Blizzaks are much softer than 3Ds. they wear out too fast. They feels like wet noodle on dry loads
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by KPC1.8TQuat View Post
    Thanks
    The LM-25s will last and you can install them now and drive on them. Its cold up in NH right now so you're fine. (I'm heading up there tomorrow to Highland MTB Park)
    I drive on my 17" LM-25s from mid-Nov through late March / early April. Got two winters on them and they are in great shape. They are a harder compound than the other Blizzak's so their wear characteristics are better. I have found them to be good in wet and dry snow as well as cold (precipitation free) roads.
    -Doug
    Mar 20 2006
    Thanks. Good to hear they hold up for a few winters. I don't beat on my car/tires anyway so hopefully I will get some good life out of them. $120 per tire at tirerack.com. Then $15 per tire to mount/install, and I desperately need an alignment. My front driver tire is worn terribly and showing camber and I have a mismatch tire on the front passenger. My two rear tires look brand new. Bad things agoin' on the rubber side.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    No Problem.
    -Doug
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    The only drawback from running winter tires in summer weather that I have ever noticed is that they tended to dry rot very quickly. The set that Im thinking of are just now wearing out (up for replacement in the next month or so) and they have a build date of 22/2005... so basically 3.5 years and they look UNSAFE to use b/c of the dry rotting. This particular car does not live a garaged life, but its also not very sunny in Pittsburgh. They are Pirelli snow tires, I dont know which model. They have lasted a good while though, probably 25,000+ miles and still have tread. They have been used year round for 3 years or so and that includes some heavy-ish towing.
    These were on an 02 ML500, not a car.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Active Member Two Rings StaringBack's Avatar
    Jul 21 2008
    Colorado Springs, CO
    Quote Originally Posted by kwimberly View Post
    Stick with your warm weather, tourist attractions, and old people. I like my 14,000 foot mountains, snowboarding, and winter tires!
    2007 A4 S-Line
