Results 1 to 4 of 4
Thread: Urgent Help
    Account Terminated Four Rings
    Nov 09 2007
    Si,NY
    Urgent Help
    Ok, so the wierd noise I heard isn't the cat. It's a really bad misfire. I checked the cat yesterday and its fine, pulled my codes at my boys house.
    Cylinder misfire dtected- randdom cylinders
    Fuel trim bank one condition- Bank 1 is 2 lean
    Random misfires bank cylinder 1 and 2
    Hmmm, I'm gonna pull my plugs today and start with the simple things first. Any ideas, might be an bad 02 sensor?
    Jan 19 2008
    Re: Urgent Help
    Sounds like it's a vacuum leak. What are the symptoms of the car at idle and normal driving?
    Veteran Member Three Rings Brooksthepro's Avatar
    Apr 29 2005
    2001 Audi a4, loud ass gocart!
    Santa Barbara, Ca
    Re: Urgent Help
    bad coilpack?
    clear the codes. switch the coilpacks around and see if you missfire on a different cylinder.
    GIAC FXK04/Gen380cc/TTMAF/FMIC/custom magnaflow/710n/Labree HFC/034 Highflow Exhaust Mani/17"Team Dynamics ProRace1/CAI/race springs/Rs4 Grille/VDO vent boost gauge/SS brake lines/x-drilled rotors/12in Infinity /600w Infinity amp
    SANTA BARBARA LOCALS!! SBEUROCLUB
    Nov 09 2007
    Si,NY
    Re: Urgent Help
    Idles smooth as silk. Letting the clutch out at idle no problems, touch the gas pedal and its so herky jerky its rediculous. Won't go anywhere for like the first 1-3k RPM then will take off for 1k rpm then herky jerk. When I say herky Jerk I mean slam your head off the steering wheel then back into the headrest type of jerking.
