Results 1 to 16 of 16
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Siemens 380CC injectors
    I'm currently Apr stage 1, bought these injectors because I wanted to go Stage 1+. Called to make the appointment and now the shop is telling me that these injectors won't work. In addition shop said that with these injectors there will be hesitation, and inaccurate throttle response. Is this true or do they just want me to buy injectors thru them?
    I've searched and theres B6's running 225tt, genesis, siemens and I think Delphi's.
    Thanks for all the help.
    Veteran Member Four Rings alexza4's Avatar
    Apr 23 2007
    19-S5||22-GV70||14-RAM1500Hemi
    Re: Siemens 380CC injectors
    Quote Originally Posted by kwik_shift View Post
    They're full of shit. I've been running thouse for over a year. Many more people here do as well. The only negative thing about Siemens injectors that they require spacers.
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    2003 A4 QM Uni EFR 6758 on meth - SOLD :((
    2003 A4 GIAC KO4 - SOLD
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Sorry for my ignorance, but what do the spacers look like and where would I be able to pick some up?
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    As far as I know, there's no problem with you running those injectors. I'm about to get a set myself and although I'm going with Revo. There are plenty of guys here that are running those injectors on APR software. The only thing that I've heard negative about the Siemens is that the idle will be a bit rougher because they're single spray instead of dual. I've talked to a couple of people that have the Siemens and they haven't experienced any problems with that.
    Did they say what injectors that they wanted you to use?
    If it's really that big of a deal, there are some Genesis injectors for sale in the classifieds right now. You can get those if you want. No spacers required.
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Apr 23 2007
    Well, just looked on ECS site. Looks like they redid the core on those, so no more spacers requirement. If you do buy them used however, make sure, because if they're older like mine you will need spacers - little alluminun washer looking rings, they actually came with injectors when i bought them.
    Now, they do say now that, these are incompatible with APR stage 1. So if thats what you're doing your shop was right after all.
    Link
    2019 S5 3.0T
    2016 A5 2.0T Cab
    2015 S5 3.0T - SOLD
    Jun 29 2008
    You can get them from just about any of the companies who are listed in the mall section of this site. Look at the section titled Tuning Shops/Resellers.
    -Damon-
    Jun 29 2008
    Quote Originally Posted by alexza4 View Post
    Link
    That says that it's only incompatible for 2002. It also says that they don't require spacers. Call them if you want to double check though.
    -Damon-
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    if they don't work, sell the injectors to me :-)
    02 A4 3.0Q6MT
    -chad
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    They will def work, been running them for a while now and not a single issue, i used 2 nuts on each side of rail for spacers, worked liked a charm....never had a hesitation or wrong throttle responce....
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    i use them. no probs.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    Put them in Thursday and got flashed at night. Works like a charm all I needed was fuel rail spacers. Shops somethimes want to rob you like your blind.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Just tell them to flash it and not to worry about it, they're trying to sell you injs.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 26 2005
    The fact that the Siemens injectors don't have the correct dual spray pattern angled to work optimally with the intake port layout of the 1.8T cylinder head, is a deal killer as far as I'm concerned.
    The Bosch TT225 injectors have the correct spray pattern that was extensively developed by the factory. While the single spray pattern Siemens injectors "work", there are several important aspects that compromise best performance compared to the Bosch TT225 injectors that provide the exact fuel spray distribution pattern needed for best overall operation in the 1.8T.
    Mar 21 2006
    Lakeland, FL.
    True about the spray pattern, but they do use a very wide spray instead. I've been running Seimens 630s for qutie some time now without any idle issues. Greg even runs the shitty 440 green tops without any problems. Those things spray like one of those shower heads on TV that are clogged with minerals from water.
    I'm back bitches!
    Aug 26 2005
    Quote Originally Posted by dirtybrd View Post
    LOL! that's one way of describing the 440 Siemens spray pattern! Yeah, the wide single cone fuel spray will result in a lot more intake runner/port wall fuel wetting than the correct dual cone spread angle spray pattern provided by the stock or TT225 injectors, as well as less fuel atomization by the single spray injector. When there is uncontrolled port runner wall wetting from fuel spray impingement, in-cylinder fuel mixture control will be effected negatively more or less depending on severity, (extra injected fuel mass needed to insure adequate rich fuel air ratios at full boost, to prevent detonation etc,) and the worst effects are at cold start up, that is what is mainly involved with the cold start lean misfire and other running problems (reduced fuel economy for example,) that occur with the non Bosch injectors.
    Mar 21 2006
    Lakeland, FL.
    Yes, they would be better,I have no choice for my application.
    I'm back bitches!
