Results 1 to 13 of 13
    Veteran Member Three Rings GarbatyA4's Avatar
    Aug 10 2007
    Ontario Canada
    GT2871R Log Discussion
    Hey All,
    First time logging and posting a log. I could really use ur help.
    I am on shitty mika tune still... 440cc bosch, FMIC 2.5"Piping, Full GT2871R, Neuspeed exhaust... Running 15psi.
    Let me know what you guys think.
    oh by the way, there are no correction factors at all with Mika Tune (never move from 0)
    I think the A/F is too lean... my Primary fuel term is plus 25%
    I think my injectors are maxing out?
    What else am I supposed to log? What should I do?
    My MAF is pooched right now
    Veteran Member Four Rings BARRY's Avatar
    Nov 02 2007
    SF Bay Area, CA
    Re: GT2871R Log Discussion
    looks fine to me.
    Jan 25 2006
    A4 2.0T
    MD
    hmmm post actual logs with the link in signature so I can do some calculations.
    Forum Moderator Four Rings actlsub9's Avatar
    Jun 13 2005
    Audi
    Fix your MAF first. 25% correction is about the most the ECU is capable of.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Aug 10 2007
    Ontario Canada
    Quote Originally Posted by actlsub9 View Post
    Fixed the maf last night, my 032 values are within 5%
    Sample rate was better, logging fewer blocks. Logged 031 and 003 also 115 (boost pressure)
    Anyways, here's some 15psi logs.
    I know i have boost leak issues hence look at the graph.
    Anyone know how to save the excel graph's as higher res and bigger?
    Aug 10 2007
    Ontario Canada
    If someone could tell me how much timing I could push that would be great!
    i don't think my tune has correction factors, So i'm just watching my knock sensor voltages, trying not to piss them off. I don't go over 20-22V
    When under load, I'm reaching no more than 10 degrees of timing. Whats an agressive tune? 16-18 degrees of timing?
    2012 Audi Q5 - Daily (slow AF)
    2013 Mini Cooper S - sold
    2005 BMW 325Ci - sold
    2007 BMW 335i - sold
    2004 VW Golf TDI - sold
    2004 Audi S4 V8 Cabriolet - sold
    2003 Audi A4 1.8T - GT2871R - sold
    2000 GMC Sonoma - sold
    1992 Dodge Stealth RT - sold
    1991 Chevrolet Beretta GTZ - sold
    Jan 25 2006
    A4 2.0T
    MD
    Quote Originally Posted by GarbatyA4 View Post
    Did you even read my post?
    Aug 10 2007
    Ontario Canada
    Quote Originally Posted by Don Supreme View Post
    yes I did, I tried saving the excel web page and making it my signature.
    CAn you not access it?
    Jun 13 2005
    Audi
    Good that you fixed your MAF. Now fix your boost leak. Everything needs to be working correctly before you get into timing advance.
    Greg - Moderator
    WWW.ACTLSUB9.COM
    Jan 25 2006
    A4 2.0T
    MD
    huh? no that does not work...
    Go to the website
    http://vagtuner.dynalias.org
    Click browse, find the log on your computer and upload it.
    It will then give you a link to post in this thread.
    Be sure to only upload the full throttle section of the log.
    Aug 10 2007
    Ontario Canada
    Fixing the boost leaks tommorrow... Anyone have an idea on what RPM's the GT2871R should boost?
    Senior Member Two Rings Dopefish's Avatar
    Apr 13 2007
    2003 Audi A4 1.8T
    Orlando, FL
    We cannot access your hard drive on your local machine. You'll need to upload the picture somewhere like photobucket and then add THAT link to your signature.
    1982 Signal Green VW Scirocco
    2004 Tornado Red Triumph Speed Triple : Barracuda CF Exhaust : Woodcraft Clip-Ons : Ermax Undertail
    Audiwissen : Coming soon
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    with your setup you should be seeing 15psi by 4000rpms in 3rd gear. 4th gear it will come on sooner, 5th gear even sooner. 9-12 btdc's is about normal for our off the shelf tunes. That is where I'm at. Aggressive would be upper teens to low 20's. I would not worry about knock voltages so much. I have been maxing mine out at 29V since 2005. How can your tune not have correction factors? I would not want to see BTDC's go below 5-6 at WOT in full boost.
