Results 1 to 3 of 3
    Senior Member Three Rings Insomniac's Avatar
    Jun 03 2008
    Hershey
    Replacing Cam Tensioner Seals on a 30v
    Ok guys, I'm tired of my oil leak, and I know its coming from that damned half moon seal. I read through some DIYs on AW and I feel I can do this job. My questions are:
    1) Where can I buy the cam tool to compress the tensioner?
    And is this absolutely needed?
    2) The valve cover gasket on the side I'm working with has recently been replaced >5k miles.
    Do I need to replace it again since I will be taking the cover off.
    3) So far I can think of a couple torx bits to get the job done. Do I need to
    torque the bolts to spec? or can I get by with my hands?
    My plan of attack, is to use the cam tool to compress the tensioner. Then unbolt the tensioner enough to slide out the old gasket and half moon. Followed by installing new seals, slapping the covers back on, and cracking open a cold one.
    Tips, Advice, Critiques? I'm not paying someone to do this, unless a local Audi guy wants to help
    i wanna buy this sucker tonight, buuuut I want to know what else I should snag too.
    free earl
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    Re: Replacing Cam Tensioner Seals on a 30v
    I'm not sure where you can buy the tool, but i've seen people fabricate their own (may have been mentioned in some of the write-ups). But to answer your question, yes, you will need this tool, or something similar, to release the tension off the chain.
    As far as the gaskets go, you could probably get away with reusing the same gasket if it's relatively new, but i wouldn't chance it. Might as well replace them while you're at it.
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Jun 03 2008
    Hershey
    Ok, so anybody with this tool wanna let me borrow it? I'd gladly throw some money towards it. Or a nice picture so I could try to have my brother CNC one?
    I was thinking of replacing the head gasket anyways.
    free earl
