Results 1 to 13 of 13
    Active Member Four Rings burner799's Avatar
    Oct 14 2006
    Hermosa Beach/PHX AZ
    road trip on a budget?
    I have limited funds...can't find a job. Have to drive my a4 about 500 miles one way then 500 miles back. I have 2 ripped front cv boots, and 1 control arm thats slightly bent. do you guys think i'll make it there and back?
    Ti.Sline: yeah my dads got shit in order
    SkunkonCrunk: i had to pay $300 and fight the city after they sprayed a bike lane on my car
    SkunkonCrunk: i hear ya, i know u guys dont get along but let bigons be bigons, or however u spell it, im at a two year
    Senior Member Three Rings TverRus69's Avatar
    Sep 02 2008
    98.5 2.8 A4 QM
    NYC, Penn State, Tver Russia
    Re: road trip on a budget?
    You'll make it there and back for sure - its the car thats questionable haha.
    Honestly i say you'll make it, if the control arm isn't in too bad of a condition and the CV boots don't get destroyed... I doubt you'll be going off roading and driving through deserts. My joints are starting to click... can't wait till the wheel finally flies off...
    Registered Member Two Rings Oranoco's Avatar
    Oct 14 2008
    Audi A4, Escort RS Turbo
    United Kingdom
    why not sort the car first? Neither repairs are costly and if you diy it they are cheap as chips. Saves a load of worry and potential damage to the car. If the CV joints are split the grease will spin out the hole (centrifugal force) this grease not only gets everywhere but leaves the CV joint dry.
    1996 Audi A4 1.8T @181bhp, 199lb/ft.... so far!
    Sep 02 2008
    98.5 2.8 A4 QM
    its like seeing how far you can go on a gas tank. You see its on "E" but try to see how many more miles you can get out of it. Honestly all jokes aside, I have to agree with Oranoco. Its all cheap repairs that can lead to expensive problems and possible (knock on wood) safety issues. If you simply must, do it, but otherwise take care of it first
    Veteran Member Four Rings CaSp3r9's Avatar
    Nov 30 2005
    Tools and toys
    Los Angeles, CA
    CV boots are like $25-$30 a piece and replacing a control arm is almost as easy as changing your oil. Personally, I wouldn't even consider leaving for a 1000 mile road trip without taking care of them first. All of the grease will eventually find its way out of the boots on the drive, not only making a huge mess but drying up your CV joints which will ruin them. Thus, creating an even bigger problem potentially hundreds of miles from home...
    As for the bent control arm, how bad is the bend? You do have two of them per side but then again, they are key components in steering/suspension. A friend of mine had a control arm snap on the highway, his car ended up sliding to a halt on the frame with the wheel damn near through his fender.
    My $0.02: Ignoring small problems = much bigger problems + safety risk to you and those around you. They're relatively inexpensive and easy fixes, git er done before you leave!
    1998.5 A4 1.8tqms, Sold
    2006 A4 2.0tqm
    I have a VAG-COM if anyone in the Santa Monica area needs it.
    Veteran Member Three Rings Bic-Ball's Avatar
    Mar 29 2007
    Is the street.
    Long Island, New York
    bent control arms lead to bad things
    http://zeroproof.com/bicball/031207_15351.jpg
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Quote Originally Posted by Bic-Ball View Post
    /\ That would blow! IMO get your car fixed first.
    Established Member Two Rings dmott11's Avatar
    Jan 28 2008
    MA.USA
    I would definetly replace the parts while its still a small job. could get alot worse, alot farther from home
    "slow is smooth and smooth is fast"
    Oct 14 2006
    bent control arm isn't really noticeable unless you lift the car. I have replaced one cv boot, but am having problems with the outer clamp staying on...I am not going to do control arms by myself and parts + labor will be like 450 bucks.
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    I have been drivin on ripped cv boots for the last 10,000 miles so you should be good.
    Sep 11 2007
    Dirty Jersey
    the bent control arm scares me slightly, seeing as they are cast aluminum and they loose a good deal of their strength when deformed
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Veteran Member Three Rings prey's Avatar
    Feb 03 2007
    2003 Audi a4 1.8 TQMS
    Parsippany
    nah nothing is gonna happen, just make ur trip, go like 65 the whole way without beating on it..
    Prey
    2003 Audi a4 1.8TQMS Unitronic Stage 1+
    Oct 14 2006
    ya hopefully it's all good. I don't have any clunking or anything and the car drives strait, tires wear evenly. no clicking of the cv joints. Just used to stuff breaking so often that I'm nervous to be stranded which is a major pain in the ass considering I still make payments on this car : ( plan on going 70 the whole way down to get uber good gas mileage.
