Results 1 to 11 of 11
Thread: left rear light
    Registered Member Two Rings
    Aug 11 2008
    2003 Audi A4 1.8T
    Plymouth, WI
    left rear light
    turned the keys tonight and it said my left rear light wasn't working, so i checked it out. looks fine, indicator light works, brake light works, and the reverse light works. has this happened before to any of you? i'm getting my oil changed next week, should i ask my man to check out my light?
    in other related news...
    do these look like they are worth my money? they look sweet.
    http://cgi.ebay.com/ebaymotors/AUDI-...18#ht_5997wt_0
    Veteran Member Three Rings 05A$SE's Avatar
    Feb 12 2008
    05 A4 1.8T Special Edition
    Dirty Jersey / Phoenix
    Re: left rear light
    try hitting your hand lightly against the light. sometimes the connection of the bulb to the circuit board is loose and wont show a full signal but the light will work. my lights were giving me problems for about two weeks. the message would come up but the lights would be fine. just play around with them and check them. it should go away.
    2005 DG On Black Special Edition 1.8T 6MT
    Built 2.0L Stroker, ETC
    2012 C63 AMG - 600HP and counting
    2006 Corvette - GTR (1 of 7) - Blue One on GOOGLE
    1998 H1 - AM General 4dr Hardtop
    1992 M998 - Slantback Project
    1990 240SX - big turbo drift missile
    1989 K1500 - LQ4 6L90 Swap
    1986 RX7 - Truck conversion, LS1, 72* angle kit
    Veteran Member Four Rings Pothole's Avatar
    Jun 02 2008
    Snohomish, Washington
    Re: left rear light
    also check if the rear fog light is working, located on the left side only, to turn it on you turn your headlight knob all the way to the right and pull out two clicks, gl
    Please Drive Right
    Aug 11 2008
    2003 Audi A4 1.8T
    Plymouth, WI
    Re: left rear light
    thanks i'll check it out in the morning, did you take a look at those smoke tails on ebay? are they worth my money? do you like the smoked look?
    Veteran Member Four Rings J-jizzle's Avatar
    Aug 28 2007
    Tools, Parts and the GTI beater
    Birmingham Alabama (Tennessee)
    Re: left rear light
    Mine did the same for a couple of days then the car quit telling me is was out. Must be a bad connection like 05A$SE said.
    Veteran Member Three Rings PCYC's Avatar
    Sep 07 2007
    04 A4 3.0 6spd, 06 A6
    Atlanta GA
    Re: left rear light
    ditto
    Senior Member Three Rings ThreePointOhh's Avatar
    Dec 24 2007
    |2004 A4 3.0Q 6SPD MT|
    New York, NY
    Re: left rear light
    is it the left brake light or tail light. the brake light is a dual filament bulb so it could appear on but one of the filaments is burnt out. check that out.
    ** I'm Gonna Drive it Till the Rings Fall OFF!! **
    Veteran Member Four Rings mdzaudi's Avatar
    Jul 30 2008
    '03 A4 1.8tqm, 91 Explorer, '05 Arctic Cat M6
    Downtown Denver, CO
    Re: left rear light
    The connectors for audi lights seem to be a bit fickle so it's not always a burnt out bulb but you may have to clean some contacts or bend them a bit from time to time to get them working properly.
    -Matt
    FCDT Member #1
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Re: left rear light
    those lights on ebay look good, but they may trigger a bigger problem than a bulb out message
    02 A4 3.0Q6MT
    -chad
    Registered User Four Rings greg@podi.ca's Avatar
    Jun 21 2008
    Re: left rear light
    The ebay lights look like shit...imo of course...
    Veteran Member Four Rings Boosted3.0's Avatar
    Jul 27 2008
    02 A4 3.0, 08 M5 5.0
    Miami, FL
    Re: left rear light
    Not sure about the rears, but my front turn signal was a dual fillment...possibly rear signal also?
    High speed Ferrari movement...
