So today since I had to change the o-ring seal on my fuel injector because it was leaking fuel I also decided to tackle the changing of my coolant flange since Im leaking there also. However in the process of removing some other pieces to get to the flange since it is a p.i.t.a to get to I was removing the oil check valve thing ( the big black looking valve that is directly behind the manifold and above the coolant flange ) and it was already broken at the base so it just popped off . How important is this piece and can I get away with not running one. It appears that if I have to replace it I have to replace the tube itself that runs under the intake manifold. What exactly does this piece valve do. Also any advice that might make my job easier on changing this coolant flange is greatly appreciated, as of right now I'm following the DIY write up. Thanks..
