Results 1 to 4 of 4
    Jun 21 2008
    NYC | ATX
    Noise coming from PSS9
    I just installed my PSS9 along with Front and Rear H&R Sway Bars not too long ago, and I'm noticing that whenever I hit a bump or when I turn, the suspensions makes a noise. Like a muffled bump, any suggestions on what it could be it.
    Veteran Member Four Rings jeremy@matrix's Avatar
    May 27 2004
    B8.5 S4, B8 S4, B7 A4A, B6 A4, B5 A4, Q7, 958TT, 955TTS, 997C2S, 996TT...
    Portland, OR
    Re: Noise coming from PSS9
    Quote Originally Posted by NYSpeedRacer View Post
    Did you load the susp bushings (ie car on jack stands) before torquing all the fasteners?
    Do you hear the sound front or rear?
    Jeremy Williams
    Matrix Integrated Inc.
    www.matrixintegrated.cc
    Jun 21 2008
    NYC | ATX
    "Load the suspension bushings"?
    I hear the sound in the front.....
    May 27 2004
    Portland, OR
    Yes, did you lower the car onto jack stands and then tighten all bushing-related fasteners? If not, you can improperly load them which can cause noises later on.
    Jeremy Williams
