So i just got a Clutchmasters Stg3 with the 6-puck disk installed from WMS since my old clutch blew up on me for no reason and its been working great, vibration is at a minimum now since ive been driving more than enough since the date of installation.
I got more news of crap my car is doing with the note that my front and rear seals are shitty, the manifold is dumped with oil, and driver side turbo had oil leaks. "You've got probably till December before your turbo goes. Just letting you know "
The crap aside, i tried calling Mike earlier today to see if he knew what the problem was with my boost but no one picked up so maybe you guys know...
4 days after getting the clutch installed (mind you, its still the stock FW but scuffed so its drivable again) everything is running great, and i was mildly boosting in 4th gear going home from school. Then i put a little more gas into it, and it pulled back off the boost and i felt a slight loss in power. Then afterwards, boost was gone for like 10 minutes then suddenly came back later.
Today i noticed that after a good warmup there was NO boost at all. I got the ASP flash from WMS a few weeks ago too...and It felt stock (or like it at least) for a good 10 minutes till i got onto the freeway. Another 5-10 minutes and boost is still absent. So i said fuck it and put on the A/C as it was swamp-ass hot outside, and going to Brea from Montebello with the windows down the whole time isn't very comfortable.So anyways, i was in 6th gear pretty much the whole way there, then for some reason as im trying to pass a car, i notice the car is boosting again as if nothing was wrong.
Turn off the car for about 2 hours, and try and run it normally again on the way back. SAME PROBLEM. This time it was for about 20 minutes before boost came back.
Couple hours later and like 20* cooler, i start the car and it boosts fine from the get go.
I dont fucking get this car. =(
*Note*
Some one told me it might be my plugs but i just had them changed the same day the clutch was put in.
