Results 1 to 11 of 11
    Senior Member Two Rings dennisS4's Avatar
    Mar 23 2008
    Tri State aRea
    Accordian Hose Replacement??
    I've been searching for a replacement to the accordion hose, something solid like silicon or Kevlar material. I know if seen pictures of 2.7 motors with solid intake hoses. I think the company was AWE that made them. I cant find them anywhere I look. Any ideas or would i be wasting my time replacing it anyway?
    Thanks in advance,
    Dennis
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Accordian Hose Replacement??
    the AWE accordion you are referring to is part of the stage 3 fueling kit they sell... there is no point in changing that unless you are going stage 3 with your car and at that time you change accordion hoses.... in my setup, which is another common route with that intake tube some call it is the RS4 accordion which is what I run, but for the RS4 accordion you need a larger MAF as well..
    Established Member Two Rings S obsessed's Avatar
    Sep 27 2007
    North Dakota
    It sees absolutely no boost pressure what so ever. The stock one is good. If yours is bad, the dealer will have one and it should be very cheap. If you are going for looks then go to any place that sells silicone hoses and give them the size. This will make your airbox move with your motor though which is whole reason the accordian hose is there, so they can move independantly.
    2001 s4 6sp stage 3
    Sep 21 2008
    new braunfels
    actually the accordian also serves as a noise baffle to eliminate the sound of air being sucked in...
    Mar 23 2008
    Tri State aRea
    I should be considering changing out my stock tbb before many other mods anyway.
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Unless you are AWE Stage 3, there is very little reason to use the AWE "accordian" hose. When the AWE Stage 3 kit for the B5-S4 was first released a few years back, it was discovered that the hose can collapse due to the vaccum created by air flow, which is why AWE now requires cutting of the airbox to allow more air flow to prevent this from happening. This is also why that most tuners (APR, MTM, EPL, ASP & VAST) all uses the RS4 accordian hose for their stage 3 kit when a larger than stock MAF housing is being used.
    So, if you are pre-stage 3, there is no need to re-invent the wheel, just stay with stock accordian and you will be fine. If you are Stage 3 and beyond, unless you are AWE Stage 3, you should have the RS4 accordian hose already.
    Quote Originally Posted by dennisS4 View Post
    That and also the By-pass valves to 710N's. If you have an F-hose (MY2000), you should change that out too.
    Mar 23 2008
    Tri State aRea
    I actually jsut changed my DV's to 710N's and my check engine light came on 24 hours later. what could have happened?.... and yes i had the keys out of the ignition for the install.
    Jun 14 2007
    2000 S4
    Connecticut
    hard to say... did you do them correctly lol? serious question... did you copy the orientation of the old valves and install them that way? it could be another problem, i had the same issue, i had a CEL and all signs pointed to DV's... I replaced them and it ended up being my MAF sensor... I have a 2000 and before stage 3 I had the bosch sensor that is common to fail and cause a cut in power at like 3-4K
    Apr 27 2004
    Pacific NW
    They shouldn't, unless you didn't install them correctly and there is a boost leak, or you have a defected BPV. VAG the car and see what the codes are.
    Mar 23 2008
    Tri State aRea
    Quote Originally Posted by Tifosi View Post
    My guess is that brittle vacuum line that the extra boost goes through the top of the DV is leaking, ill VAG it and also replace that vacuum line ASAP and see what happens.
    Any ideas where to pick up some Samco 3mm vacuum line?
    Thanks guys,
    Dennis
    Apr 27 2004
    Pacific NW
    Thanks guys,
    Dennis
    I think PureMS & ECS tuning carries them, as many others. They are nothing that special that it has to be "Samco", you can even try your local autopart stores or just get the OEM ones. They are inexpensive and they work just as well. If there is indeed a leak, it is better to get it fixed ASAP as oppose to wait for something fancy like a silicone hose.
