Results 1 to 4 of 4
    Senior Member Two Rings raykwok's Avatar
    Aug 30 2007
    00 S4
    Morristown, NJ
    hey will these wheels fit on my s5?
    will s4 wheels fit on my s5 with no spacers or anything?
    19x8 or 19x8.5 5x112 +35 all around.
    euro.techniks | east
    2008 Meteor Gray Audi S5
    Sponsors:
    DPE ~ Euro-Gear ~ AWE ~ KW
    2004 Silver Audi A4 - stage 2+
    2000 Nogaro Blue Audi S4 - stage 3
    Registered Member One Ring snow day's Avatar
    Aug 16 2008
    Rochester, NY
    Re: hey will these wheels fit on my s5?
    No, the bore diameter of S4 wheels is 57mm. You need wheels with a bore diameter of 67mm to fit your S5. If the S4 wheels have an interchangeable centering ring, you may be able to replace them with new centering rings. I know, for example, that BBS can supply new rings for their wheels for $4 each.
    2009 S5 6MT Phantom / Black Alcantara / SS Trim / Drive Select / Tech / Nav / B&O
    Aug 30 2007
    00 S4
    Morristown, NJ
    lol I don't get it :P I'm bad with wheels and stuff
    Sponsors:
    Aug 16 2008
    Rochester, NY
    What don't you get, the bore diameter description?
    When you look at the inner face of the S4 wheel, the hole in the center has a diameter of 57 millimeters. When you mount this wheel onto an S4 (or A4 or A6 or some other Audis), the hole fits tightly over the hub sticking out from the brake disc. The tight fit is what actually centers the wheel on the hub. The lugbolts just hold the wheel to the hub.
    When you look at the inner face of an S5 wheel, the hole in the center has a diameter of 67 millimeters to fit over the larger hub on the S5. If you try to mount the S4 wheel with the smaller hole, it won't fit over the larger hub.
