Results 1 to 6 of 6
    Feb 17 2008
    Ottawa Ont.
    Unitronic 2.7T stage3/GTfile emmision test results.
    Relevent mods:
    NGK BKRE8E-IX, gapped to .026
    Siemens 630CC injectors at 4bar
    85mm VAG/Unitronic MAF housing
    X1 intake
    GHL downpipes, HF cats.
    Unitronic ECU
    Test 1, 2 stage idle test
    conditions.
    oil temps 75 degrees, when i parked it, cooled down to 60 by the time it was my turn. basically sat outside for 20 minutes. It was about 6 degrees outside.
    idle was +100 and +20 idle torque offset
    2500 rpm
    HC ppm: 431, limit:150 FAIL
    CO% 1.52, limit: 0.7 FAIL
    idle: 898 RPM
    HC PPM: 192, limit: 150 FAIL
    CO% 0.72, limit: 0.70 FAIL
    Dang!
    I drop the idle and torque offset to 50rpm and +5, get the car nice and hot and try again.
    oil temps at 100C
    2500 RPM
    HC PPM: 92 limit 150 PASS
    CO%: 0.30 limit 0.7 PASS
    Idle: 842
    HC ppm: 20 limit 150 PASS
    CO%: 0.04 limit 0.7 PASS
    Holy shit. What a difference it made just getting the car up to temp. Those are pretty outstanding results considering the level of modification, high flow cats with a few years on em etc.
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Unitronic 2.7T stage3/GTfile emmision test results.
    My car breathes white c02 smog of fury when she's cold. I mean like spits that crap out like it's no buddies business, but when she's all warmed up, she passes perfectly.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Jan 25 2006
    A4 2.0T
    MD
    Good info.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    .026 gap? that a lil wide no?
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Keeping the car and most importantly the cats up to temp is very important. The drop you had in oil temp is huge for passing smog. I had to pass smog here in Cali earlier in the year and my car failed after only sitting for 15 minutes in the summer heat. To pass I had to drive around for 10 minutes and literally drive right in to the dock and get tested right away to barely pass smog.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Remember's me when my EGTs were shot. Too much correction at cold and under boost. Still need to change them we only eliminate them for now but it's way better.
