Results 1 to 7 of 7
    Registered Member Two Rings 4BLKRNGS's Avatar
    Oct 22 2008
    Monrovia, MD
    Boost problems no more!!!! im an idiot :) some pics too.
    ok so i have been having the same problem for months on end, low boost. i was only boosting 12-13 psi on a GIAC chip and i was pretty sure that was not right. i fixed every air leak in the entire engine including the crank case breather hose. still 12-13 psi. i put on all silicon venir boost hoses. now at 13 psi. then my thought was n75 valve so i got an n75 race valve. now 14 psi spike. well today i was messing around with the vag com and turns out thethrottle angle when floored was only 62.7% WTF???? so i took the laptop to the front of the car and twisted it to WOT and the comp said 86.4%. turns out the cable was loose so i tightened it and now i spool up real fast to 17-20 psi depending on the temp outside. car feels so much faster and now i feel so much better. thought i would share with you all since i had the hardest time finding the problem i almost just gave up on it.<br>
    by the way my mods are:<br>
    godspeed front mount intercooler<br>
    ecs n75 race valve<br>
    silicon hoses<br>
    GIAC chipped<br>
    baileys dv<br>
    and a shitty ass paint job see for yourself. keep in mind im poor so i know it needs to be lowered but i cant afford that just yet. window tint will come soon too.<br>
    <center>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/Audi/1022081659.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/Audi/1022081659a.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/Audi/1022081700.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/Audi/1022081700a.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    <img src="http://i470.photobucket.com/albums/rr61/4blkrngs/Audi/1022081700b.jpg" alt="Photobucket - Video and Image Hosting"><br><br>
    </center>
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    Re: Boost problems no more!!!! im an idiot :) some pics too.
    wow this is pretty cool actually... i have only been boosting 14-15 psi with my GIAC software, and after replacing my n75 with the race version there was only a very slight difference.
    i tried checking all of the hoses like you did and i found no boost leak. maybe i am having the same throttle body issue, if i can find someone with VAG COM i will definitely try this!!
    {99.5 Avant}
    May 22 2008
    az
    {99.5 Avant}
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    [/QUOTE]
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    Oct 22 2008
    Monrovia, MD
    thanks for fixing the pictures i don't know why photobucket hasn't been working recently
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Quote Originally Posted by 4BLKRNGS View Post
    You need to select the one that says its for forums so it gives you the brackets ([ & ]) and not html.
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    good right up! Now go paint those lowers!
