Results 1 to 8 of 8
Thread: LED's
    Veteran Member Four Rings Monchichi8's Avatar
    Jul 03 2004
    2004 S4, 2005 Grand Cherokee Hemi
    Boulder,Colorado
    LED's
    I want to change some of my bulbs to leds. Front turn siginals. Rear turn Siginals and side markers and Rear Licence plate replacements. All 4 sets cool white to match the Hoen fogs and Stock Hids. Not seeing which bulbs from here that I need(cross reference isn't matching)and also do I need these electronic Led flashers and resisitors for some, for all, how many, which ones??? A little confused and just want to make the order once with no mistakes. Any and all help greatly appriciated. Thanks, Chris
    http://www.superbrightleds.com/1157.htm
    Veteran Member Four Rings trexturk's Avatar
    Mar 20 2007
    '11 Sprint Blue S4, 03 996 Targa
    Chicago Burbs
    Re: LED's
    i have the leds on my rear turn signals and i had to put the resistors on each side.
    im sure you gotta put them on each light
    if you dont im sure it will blink fast and have a warning light
    Senior Member Three Rings simona's Avatar
    Jun 18 2007
    B7
    silicon valley
    Re: LED's
    Its not as straight forward as just replacing a bulb with the new LED bulb. You have to know which resistor to use for specific bulbs and connections. Also the resistors depending on the power input, will generator HEAT. so you cant just put the resistor anywhere otherwise it may end up melting other things around it.
    If anyone is an electrical engineer or a car electrical specialist here, i would like to hear their advise.
    Senior Member Two Rings silvertze's Avatar
    Oct 22 2008
    2011 Jet Black 135i (M Package)
    Montreal
    Re: LED's
    Not to treadjack or anything...I bought some superbright white leds to replace the liscence plate lights and they work fine when the cars not on, meaning no key but lights are switched on, but when the car is running they are on for a few seconds and turn off. ot only that but my passenger taillight seems to have burnt out in the process...any help or how tos?
    Jul 03 2004
    Boulder,Colorado
    Re: LED's
    Quote Originally Posted by simona View Post
    For sure, Please. I want that super clean look of bright white everywhere just need a parts list. Going to look sick switching lanes.Thanks again everyone!
    Jul 03 2004
    Boulder,Colorado
    Re: LED's
    ttt
    Jul 03 2004
    Boulder,Colorado
    Re: LED's
    found out that ECS has the the licence plate bulbs but I still need a part list for the rest. Any help appriciated. thanks, Chris
    Jul 03 2004
    Boulder,Colorado
    Re: LED's
    ttt
