    Veteran Member Four Rings SuperAvant's Avatar
    May 30 2007
    MA
    Think I will have rubbing issues?
    My wheels finally come tomorrow after waiting about 6 months. THey are 19X8.5 with a +35mm offset. I am dropped pretty low about 25" i believe (i will have to measure again). The tires are 235/35/19. Do you guys think I will be fine with rubbing issues?
    2014 R8 V10 - Gated
    2005 S4 Avant 6 Speed - JHM Stuff
    2017 TRDoffroad 4 Runner
    Veteran Member Three Rings J.the W.'s Avatar
    Aug 30 2007
    2014 CP M5, 2006 Pathfinder LE
    Az.
    Re: Think I will have rubbing issues?
    I've got the same size wheel but I'm running a 245. I rub in the back a little over bumps and dips if I'm going too fast. I'm not sure of my hieght though.
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    i wouldn't worry about rubbing. I have the exact same set up i have on my car and i only rub in the rear over large dips in the road and i am tucking tire in the back. Once i raise it up im sure ill have no problems.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Veteran Member Three Rings Meradin's Avatar
    Jul 14 2005
    White Plains, NY
    I think that you should be fine. I am at 25.25" with ET +32 with the same sizes tires and wheels without any rubbing. The extra 3 mils should be more then enough for the extra drop.
    2012 S4 Prestige S-Tronic
    Phantom Black /w Titanium Package
    Modded...
    Veteran Member Four Rings mioStile's Avatar
    Sep 25 2006
    I wouldn't worry. I'm going to be running a 9.5 with an et 36...I'm a little bit worried - but I think I'm going to be okay. :)
    Current Iggnshn: 2007 4.2L 6 speed quattro S4. Neuspeed catback. 20x8.5/20x9.5 BBS RSGT. PSS9. USC license plate. always my work in progress.[/FONT]
    AMA
    Together we can all defeat 2.0T and 2.7T crime
    Ya, I'm that guy...
