Results 1 to 4 of 4
    Registered Member Two Rings
    Sep 30 2006
    1998.5 Audi A4 1.8TQM
    Tallahassee
    Safe boost on stock internals
    How much boost is safe with a 3071r .63 on stock internals (CTapp 630)? I'm planning on doing the internals soon, but i'm doing everything at once so until i raise that money i'm gona run it on stock internals. its a 98.5 AEB
    98.5 A4 1.8TQM
    Feb 17 2005
    Sarasota, FL
    Re: Safe boost on stock internals
    Every car is different in what power it makes for the setup and what the stock internals can hold. I would keep from going too much if at all over 20psi on stock rods
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I'm running the same setup (although I wouldn't say my car is "running" right now)....but I'm gonna be running 15-16psi on low boost settings and about 19-20psi on high boost. I won't be using the high setting much at all, since my plan for going BT wasnt' to have a high HP beast, but to have around a 280whp daily driver. I don't want to have to build my internals, so I'm gonna play it safe, run low boost, and make sure the car runs tip-top so I don't damage the motor
    But remember, you can also do damage to your head, regardless of WOT boost level if you over-rev it. So be safe and don't constantly push your turbo to the redline, or else bye bye motor if you happen to mis-shift or over-rev. Your bottom end isn't the only thing that can break
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Four Rings Rosati's Avatar
    Nov 17 2004
    B5 Brilliant Black A4 1.8TQM
    Northern New Jersey
    I was @ 21psi on my 28RS for a while and shes still at great compression
    Then again, its all about your A/F @ that point......
    make sure your tune is straight, but in essence, you should be good
    But remember each car is different
    * Gone but not forgotten - BTA4 GT28RS w/ all mods 400chp
    https://www.facebook.com/media/set/?...1463643&type=3
    Current: 1994 Mazda RX7 Chaste White
    DIY B5 Head Replacement Guide: http://www.audizine.com/forum/showth...al-and-Install
